pipe for lrp z.28r spec 3
hello to all,its been a long time since i been on here, but i have a question, to which i know yall have the answer, my truck is a 8.0 ,with buku muffler ,and i want to switch to lrp z28r spec3 motor and want to know what header pipe and will the clutch set up off the 8.0 work on new engine,thanks so much
IL
RE: pipe for lrp z.28r spec 3
ORIGINAL: big country 1969
hello to all, its been a long time since i been on here, but i have a question, to which i know yall have the answer, my truck is a 8.0 ,with buku muffler ,and i want to switch to lrp z28r spec3 motor and want to know what header pipe and will the clutch set up off the 8.0 work on new engine,thanks so much[img][/img]
The 8.0 is a converted Thunder Tiger heli engine and uses a side exh, so you need the stock MGT 4.6 header (I'm guessing).
If the Buku uses a standard coupler instead of springs, it should fit right on as long as you don't have the dual tank mod.
IL
The 8.0 clutch is good since it's a 4 shoe, and I don't know if anyone makes a standard 1/8 scale 23T CB.
I used an 18T CB when I ran the Savage clutch because the I.D. of the 8.0 CB is larger diameter.
hey slayerdude have u heard of 4 channel mood have u heard of this and can u do this with 2.4 reciever do i have to have a am reciever for this thanks again
