eMGT Forward Only Conversion
GA
I am sorry if this has been asked before, but I could not find it.
If I install a FOC will I have the reverse from the electric motor or do I loose it totally.
Or
Is it a better idea to scrap the trranny for a center diff
Or
MN
The FOC is for nitro as the engine turns one direction. It removes the reverse gear. With electric, pending the esc has reverse, you will then get reverse back with FOC installed. I would however scrap the stock trans for a center diff. Ive got center diff mounts on order, as well as the rc8t factory team center diff.
