Team Associated - Monster GT Discuss all things AE MGT right here!
Monster GT anyone have one?
Old 08-25-2007, 08:41 PM
  #7176
Snaut Rocket
Snaut Rocket's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Monster GT anyone have one?
hey guys whats so special about the 23mm wheels. I keep hearing alot of you getting them. I know theres more of a tire selection for them but is that it. Are they just a bigger wheel.
Snaut Rocket is offline
Old 08-25-2007, 08:44 PM
  #7177
duckedup
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can get 23mm hex in Maxx and 40 series both. The larger hexes are to keep the rims from stripping out. Personally, I'd recommend going with 17mm instead, the 23mm put a lot of stress on the 14mm axle stubs, they are prone to breakage. If you do get 23mm, get the Dace adapters, people have had the most luck with those.
duckedup is offline
Old 08-25-2007, 09:58 PM
  #7178
scottywilkes
scottywilkes's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
DACE RULE, u will never break a axle or pin with dace hexes, as they use the old 14mm hex to mesh onto as opposed to the proline hexes which only use the axle pin.
The dace do not put alot more pressureo n the pin than the 14mm hexes, as it uses the 14mm hex. If u get 23, dace is the only way to go, the other will just strip out or break axle pins
scottywilkes is offline
Old 08-25-2007, 10:10 PM
  #7179
Evader ---> MGT
Evader ---> MGT's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Too late scotty, I already got it...
Hopefully it drops in alright...
I CAN"T WAIT!
Evader ---> MGT is offline
Old 08-25-2007, 10:13 PM
  #7180
scottywilkes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the first batches were pretty good, there been a bad batch lately and this is why alot of people are having trouble with them, so hopefully u got 1 out of a good batch, there pretty decent if its a good one.
Old 08-26-2007, 12:29 AM
  #7181
duckedup
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: Evader ---> MGT
I'm Freaking gonna get an Axial .28!!!!
MY current engine took a serious crap on me, so I need a new one! W00T!
And what else do I need to have this babe running? A nova mount? Linkages? Flywheels?
Goodluck with it [sm=thumbup.gif] I'm pretty sure all you'll need is a longer throttle linkage. Everything else should be good.
duckedup is offline
Old 08-26-2007, 12:57 AM
  #7182
Evader ---> MGT
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've actually seemed to make the stock linkage work with the brakes and carby. Yay! IDK, I'll start break in in the morning. I'm so happy!!!
I will get a longer linkage to feel safer, because the current one barely fits, but it'll work for a few tanks of running around.
Old 08-26-2007, 01:15 AM
  #7183
scottywilkes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yeah i screwed with my collars and moved the horn so i could run the novarrosi carb, it holds up great. No need for a longer linkage
Old 08-26-2007, 03:13 AM
  #7184
Evader ---> MGT
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yup, exactly what I did. Hopefully it holds up to a few jumps...
Old 08-26-2007, 06:50 AM
  #7185
scottywilkes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
put it this way, ive taken a few upside down landings, taken a 20 metre tumble down a steep hill, a few nosedives, a few rear enders, a few t bones, ALOT of wheelies and its still holding up AWESOME!
Old 08-26-2007, 11:38 AM
  #7186
Snaut Rocket
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
congrats guys we just broke 7000 post
And duck up does the zombies fit directly on to the 23mm size wheels. Cause im going to get them in stead of the big joes becuse they are cheaper.
Old 08-26-2007, 11:48 AM
  #7187
snowbl!nd
snowbl!nd's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You can get 23mm hexes on both maxx size & 40 series wheels...
snowbl!nd is offline
Old 08-26-2007, 01:45 PM
  #7188
hpi firestorm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i have a question when my truck is at the last little bit of gas it takes of so what could i do to keep it from doing that?
hpi firestorm is offline
Old 08-26-2007, 01:51 PM
  #7189
Snaut Rocket
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I dont understand your question. when your at the leat bit of gas you truck takes off. that doesnt make no sense.
Old 08-26-2007, 01:54 PM
  #7190
hpi firestorm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
i starts to rev high and starts to go a little bit faster
Old 08-26-2007, 02:13 PM
  #7191
CTDave
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sounds like it is leaning out when the gas runs out.Try richening up the hs just a tweak and see if it helps.
CTDave is offline
Old 08-26-2007, 02:16 PM
  #7192
hpi firestorm
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ok
Old 08-27-2007, 08:56 PM
  #7193
Coadster67
Coadster67's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, My MGT is oficially famous here in welland.
I was at the skatepark doing some backflips offa the quarter pipes and stuff, and a paper guy came along and got a couple of good shots of my truck and I, as well as the truck catching some massive air. Then when he left, my throttle started sticking. disconnected it offa the servo and its binding up quite a bit. so i fugure ill pull it apart and clean it and whatnot. BTW can i use "nitro Blast" to clean out my carb or should i use WD-40?
Coadster67 is offline
Old 08-27-2007, 09:08 PM
  #7194
BuzzBomber
BuzzBomber's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
nitro blast is fine. lube it with some after run or marvel mystery oil when you're done.
BuzzBomber is offline
Old 08-27-2007, 09:09 PM
  #7195
Snaut Rocket
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would use hpi nitro cleaner but its probably the same thing as the stuff you got.
Old 08-27-2007, 09:17 PM
  #7196
Coadster67
Coadster67's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Uhh, this may sound like a noob question, but how do you get the carb off? i took out the screw but nothings moving
Old 08-27-2007, 09:46 PM
  #7197
Snaut Rocket
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Can some one tell me why this wont work with the mgt.
http://www2.towerhobbies.com/cgi-bin...&I=LXPLZ9&P=SM
Read the spec if you dont believe me. I was going to get this one cause its got more rpm.
Old 08-27-2007, 10:14 PM
  #7198
docphysics
docphysics's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cuz you can't start it silly!!!!!!!!!! Its got more revies cuz less mass from no pull starter!
docphysics is offline
Old 08-27-2007, 10:34 PM
  #7199
Evader ---> MGT
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You need a starter box. Our chassis is a block w/ no holes for the flywheel.
Old 08-28-2007, 12:31 AM
  #7200
Coadster67
Coadster67's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Nvm, figured it out
Display Modes
