Team Associated - Monster GT Discuss all things AE MGT right here!
Monster GT anyone have one?
Reply
Old 05-02-2008, 03:28 PM
  #8601
Hardin Valley Magic
Hardin Valley Magic's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Monster GT anyone have one?
Thanks I have a hitec 645 mg that I am going to swap in it...133 oz/ torque instead of 108.
Hardin Valley Magic is offline
Old 05-02-2008, 03:33 PM
  #8602
docphysics
docphysics's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
the number of teeth on the spline is different for each servo, so you will need a new servo saver, or adapter.
docphysics is offline
Old 05-02-2008, 04:56 PM
  #8603
Evader ---> MGT
Evader ---> MGT's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I recommend this servo.
http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXNRT1
Almost 200oz for $5 more.
Also, [link=http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXS361&P=ML]this[/link] will fit your servo, is stronger than the stock servo horn, and is acutally a servo saver. So is the stock one, but it sucks and costs much more.
Evader ---> MGT is offline
Old 05-03-2008, 05:10 AM
  #8604
scottywilkes
scottywilkes's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
well race day was today, not a hiccup from the MGT, ive resorted to not bothering with the grub screws in the centre CVDs anymore, the pins ive just heatshrinked in there.
Worked great for about 2 hours of running
So yeah, finished 3 finals and the A main, the MGT stalled out for no reason after a jump in the amain, i rushed and started it but by that time i had lost 2 laps, so throughout the race i hammered through the track, finishing in 2nd 30 seconds down, not bad for being out for 2 laps lol. All in all im very happy, the stock arms have way to much droop in them though, so RPM arms will help massivly. Got my self a 9mm sportwerks carby to put on the SH to, so that should liven it up a bit from the stock 6mm mach carby.
scottywilkes is offline
Old 05-03-2008, 10:29 AM
  #8605
Hardin Valley Magic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Evader -> MGT
Thanks I'll run what I got till I save up enough for those pieces...
Old 05-03-2008, 12:27 PM
  #8606
Evader ---> MGT
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Wow, yeah that'll help the engine a ton!
What size heatshrink did you use? I've been having the problem of losing grub screws wayyyy to much too. GRRRRR
I've gone through a pack in like a month! With locktite![:@]
Old 05-03-2008, 07:32 PM
  #8607
scottywilkes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
yeah, my front one is good, havnt had a problem, the original grub screw and pin are still in there, i recently got a new rear centre CVD, and the grub screw was always working its self out, even with redlocktight and taping out all the old threadlock.
The Heatshrink im using is from work, its a high strength automotive heatshrink from wurth, once shrunk it goes hard enough, but not to hard so it has some slight flexibility, awesome stuff. So yeah, dont have to worry about them dam fins anymore lol.
Im hunting down some 40 series velocity 23mm rims and foams so i can try out my bowties on the track, see if it helps with stability at all. And ive got some RPM arms coming, as mine are stuffed so i resorted to using the stockers lol.
I originally had a ported 9mm SH carby on it, but that developed a nice gauge in the carb body where the slide slides, so it had a habbit of leaning out at idle and increasing idle or stalling, it went like a rapped ape though. So il be happy to get a larger carby back on the ported SH28 prospec, as the porting comes to life when it can breathe properly
Old 05-03-2008, 07:37 PM
  #8608
Dirty South Racing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, I've been wanting a m/t for awhile now and finally broke down and got one. After much researching and the fact that everyone around here runs a Savage, I decided on the MGT 4.60 SE, which I got yesterday and as I type I'm installing the foc, rpm a-arms all the way around, and after reading the last few posts heat shrinking the pins in the center cvds, while I have the tranny out. Anyway just wanted to thank everyone for the usefull info in this thread.
Dirty South Racing is offline
Old 05-03-2008, 07:44 PM
  #8609
Snaut Rocket
Snaut Rocket's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your lucky they stated all that in this page of you would of spent some hours looking through the other pages.
Snaut Rocket is offline
Old 05-03-2008, 07:45 PM
  #8610
scottywilkes
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
no worries mate, its a great truck, but like most, it has a few flaws, personally the biggest in my opinion is the transmission, the reverse mechanism is just way to sloppy, and the hard hitting while running takes its toll on the gears, pins, shafts and OWB, once i got rid of the reverse im still on the same OWB, ive managed to strip a few gears, snap a few shafts etc, but the track, and how i drive dosnt help that either LOL
Heatshrinking the pins is a good idea, saves alot of frustration from something so small ruining your day.
Id suggest cutting a small strip of heatsrink and heatshrinking the grub pin that holes the blue cup onto the transmission, and heatshrinking the silver pin that holds the centre CVD to the blue cup. Also another place is the diff cups, what the centre CVD goes into at the diff ends, it has the same type of grub shaft as the blue cups, heatshrink them in and your good to go.
Also another cheap and easy mod is to shim your diffs, they have some slop in them from the factory, not alot, but enough, after a while this will eat at your ring and pinion teeth and eventually u will strip the diff.
Heres a link on how to do it
http://www.monstergt.com/articles/tr..._diff_shim.php
Also heres a link to the proper instilation of the FOC, the directions that come with the FOC are wrong.
http://www.monstergt.com/articles/transmission_foc.php
Hope that helps mate
Old 05-03-2008, 07:47 PM
  #8611
Evader ---> MGT
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Cool! Sorry you have to install all that stuff right off the bat (extra costs...), but it's hugely worth it in the long run!
Hope you have fun breaking it in!
Old 05-03-2008, 10:22 PM
  #8612
Dirty South Racing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: Snaut Rocket
I read all the pages, I have no life LOL. I just like to know as much as possible about anything I'm going to buy.
Old 05-03-2008, 10:24 PM
  #8613
Dirty South Racing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: scottywilkes
Thanks, but I figured out the instructions were wrong the second time I tried to put the tranny back together.
Old 05-03-2008, 10:48 PM
  #8614
Hardin Valley Magic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
LMAO!!! All this heatshrinking to hit home today for my brother.. He has been trying to get his tranny to shift right. It shifted correctly (finally). And the front wheels were spinning like all heck.. The rears were along for the roll...lol So he lost the pin and grub screw that holds everything together. So now it is time for a new set.
As for mine, the only conplaint I have after a week of giving this thing a hard time, is the wheel nuts back them selves off just enough to wobble. So I keep retightening them. I guess its time for new lock nuts. Man this thing is great. Plenty off tumbles, flips, only thing that broke has been a rear turnbuckle when I slid sideways into a curb after a fun spped run across a parking lot showing off. My fix was OFNA ends on a set of traxxas shafts. They are a lot thicker!!!
Old 05-03-2008, 10:52 PM
  #8615
Evader ---> MGT
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Double nut the wheels. Put an extra nut behind the stock one and it'll never loosen.
The traxxas turnbuckles are thicker! A friend used them temporarily, but if you could tell us if they bend or not after some use (the stock ones bend like butter), that'd be awesome!
Old 05-03-2008, 11:12 PM
  #8616
Hardin Valley Magic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well lets see... Broke it on Wednesday night went straight to LHS. Run it every night since at least 2 tanks a day, as of right now it is now even bowed at all.. LOL! 3 days and counting.
Old 05-03-2008, 11:44 PM
  #8617
Evader ---> MGT
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What kinda running you doing? I might have to invest in these if they last like Lunsfords since they're way cheaper.
Old 05-04-2008, 07:52 PM
  #8618
Hardin Valley Magic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well it gets run at our "custom" back yard beast of a track. The jump will send it about 5 feet in the air and the other small jumps are about 2-3 foot jumps. I have landed on every single side of this thing. Lawn darted it a bunch, landed staight on the rear wheels,each, and it has cartwheeled many times. And still no bends. That was just today. Yup I gotta get better at landing.
Here are a few pics of our track. The camper top flat top is now gone so it is a heck of a jump. circle back through and there are 2 whoops. On the back stretch is a jump, on the long front there are two jumps like whoops but if not hit right it will cause a front flip...We run this track in the clockwise direction.
Also the last pic is a Toyota climbing the hill we go down to the track. I ran my MGT up that today. That was a sight to see!!!!
ID:	942936   Click image for larger version
ID:	942937   Click image for larger version
ID:	942938   Click image for larger version
Old 05-04-2008, 08:01 PM
  #8619
Evader ---> MGT
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
lol, looks like that camper top could do some damage if you hit it![X(]
Old 05-04-2008, 08:18 PM
  #8620
Hardin Valley Magic
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I hit it with my evader a got pizzzzed. So we moved it and now you jump where it WAS at!!! BIG AIR!! (for us newbies) LMAO!! What is real cool is today, I would jump the big jump land on the rears and carry them to the hairpin turn and jump the bank we made for the turn. Land in the grassy spot and hit the wide turn and do it again!!!
Old 05-04-2008, 08:25 PM
  #8621
Evader ---> MGT
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Yeah, I love doing that with my burms too. We wanted to keep them nice, but it's too fun to jump them!
Old 05-05-2008, 02:34 PM
  #8622
Dirty South Racing
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Didn't want to read back through all the posts, so what is the best replacement glow plug?
Old 05-05-2008, 03:25 PM
  #8623
docphysics
docphysics's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
OS 8's work great!
Old 05-05-2008, 03:48 PM
  #8624
Snaut Rocket
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
at a gallon and a half and im still on the same os 8
Old 05-05-2008, 06:23 PM
  #8625
Elite_Tux487
Elite_Tux487's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well.. I broke a few parts today..bad ass bashing session btw. I found a nice abandoned construction site with 15 foot high jumps. Ill post pics of the carnage later. So far that I can see I broke, front and rear lower a arms, bent shock shaft, broken body post, bent turnbuckle, some how the exhaust got caught into the fly wheel or clutch bell and it ate it and sliced a small gouge at the end and started pulling one side off. That just ended up blowing oil ALL over the truck. I ran the truck for 5 tanks with just half a lower A arm up front on the left and one shock on one that left side. For the body posts..I guess tower is out of stock, are there any other substitutions that will fit?
Elite_Tux487 is offline
Contact Us Archive Advertising Cookie Policy
