OFFICIAL MONSTER GT 8.0, MMGT FORUM
#1826
NY
RE: OFFICIAL MONSTER GT 8.0, MMGT FORUM
bathtime for a well-bashed mgt (both body posts and the stock body were sacrificed this day. Rioll cage soon to come once my nylon rods get shipped. lol.
#1830
NY
Those are IMEX Maxx Dawg tires. I love emm....use to run them on my Mini. They are a harder compound and the side walls doesn't flex as much. My truck has never rolled with those tires on pavement. I normally run Big Joes for bashing, but the IMEX are a lighter (weight) alternative.
#1832
whats the best upgrades for the 8.0?
just got 1 and love it. But the a arm broke with in 15 tanks.
want something that will hold up.
thanks
thanks
#1834
NY
RPM arms and Factory Team Shock caps
RPM arms are supposedly unbreakable. I notice they lower the truck a bit..but makes it handle alot better and doesn't roll over as much.
#1835
TN
hello everybody i have a mgt 8.0 that i just installed a vgracing roll cage on it , it also has the nova cooling head ,spinners and 40 series tires , buku outlaw pipe, heres a picture
#1838
Could someone please tell me some basic settings for the optional pipe? I left my car over winter pretty much and tried to start it up now and I can't remember the settings so I reverted to factory but those are waaay to rich (Doesn't even start, you hear some bangs and a ton of smoke coming out but then it just dies.)... don't really have the motivation or time right now to sit down and try to start it up with a ton of different settings with one working worse than the other.
#1839
WA
Made sure you have good fuel,byron 20% nitro it good,set high speed needle turn alway in,back out three turn,low idle,turn transmitter on,turn on power from the truck ,open full throttle ,turn small needle adjust alway in,back out 5 1/2 turn,that factory seting to begin.Good luck and have fun.
#1840
Hi Guys looking for help if poss, The engine in my MGT 8.0 has just gone bang connecting rod snapped and piston head damaged to replace these parts will cost me £95 or i can replace with a brand new engine for £110, my question is are there any better engines that can be dropped straight in to the truck or is the stock as good as it gets?? I have no problems with the .50 but if i am spending £100++ there may be better options, The other question is what would cause the damage i incurred to happen, i was running well and it just stopped out the blue is it somthing i could have avoided, thanks in advance.
#1842
CA
Ok so Im sure the answer is burried somewhere in here but I can't find it. So I am planning on picking these wheels and tires up for the 8.0 [link]http://www3.towerhobbies.com/cgi-bin/wti0001p?&I=LXZSW3&P=ML[/link]. My question is what will I need to make these fit the 8.0? Some parts links would be greatly appreciated. I know I need some type of hex adapter but I don't know which is the correct one. Thanks in advance.
#1843
I found out you'll need to use Savage Flux 17mm hex's. Apparently they are the only ones that fit without any modifications. You can get them from Ebay for a great price.
http://shop.ebay.com.au/i.html?LH_Av...m+hex&_rusck=1
#1844
CA
ORIGINAL: ausrcnut
Thank you!!
#1846
I know it may not interest many people no more but if anyone wanted to finish their MGT Knuck-mod off, I have some Delrin retainers available. I have enough for about 9 MGT's at present.
#1848
For the MGT Knuck mod. Basically upgraded the suspension to make it stronger, but it proved to be a very laborious task and a lot of skill involved. These are just retainer collets for the larger axle carriers
#1849
I know this thread is quite old but has anyone ever done the lrp engine swap? I got 3/4 of a gallon through my mgt 8.0 engine but i dont really like how touchy the carb is and how unreiable the temps are. I was wondering how much diffrent in performance the lrp zr30x engine is compared to the 8.0 engine. Or maybei should try a diffrent carb first? It runs super good after tuned. Dosnt seem to hold a tune for crap. But after playing with it for a whole tank then i can have fun with it. Id rather have a reliable engine start it and run it then a heap of metal that needs to be fabricated all the time
#1850
Hi. Yes very old thread but much loved. I lost a lot of my RC gear due to a fire in my garage. My Redcat was totally burnt, lost all 3 transmitters, RC bag with all accessories, batteries, glow igniters, all bodies and a few plastic parts sticking out like body posts etc. Was a massive bummer. So to do anything I need brand new radio TX and RX, all new batteries and starting gear etc and new bodies. I need a new transmission for the 8.0 as well. But, out of all this mess, I did experiment with a .32LRP that I installed in the SavageXL. I only just got it run in and not even fully tuned but it was a monster!! So I would definitely call it a good contender for the 8.0. Has a really nice cooling head on it too. Try the .32LRP. The .30 revvs higher but the .32 has more torque and still revvs quite high (higher than the 8.0).
