Just got a used MGT 4.6, will need help setting the 2 speed trans
TX
RE: Just got a used MGT 4.6, will need help setting the 2 speed trans
I seem to remember that you adjust the shift point screw out to cause it to shift earlier. You want it to shift to second gear at about 15-20 feet after you go WOT. I have two Nitro cars and both had to be adjusted to shift earlier. Look in the manual to find that screw. For both of my cars it is a 2 mm allen screw that is kinda hard to find and get to.
MI
ORIGINAL: Bmr4life
For the monster GT, can it be adjusted without taking the trans apart?
As far as hints, like most trannys it only takes a very small(like 1/8th) turn to make a difference.
