$149 Brushless System!!!
FL
[link=http://www.hobbycity.com/hobbycity/store/uh_viewItem.asp?idProduct=9127&Product_Name=Turnigy_Brushless_Car_Power_System_23 50Kv/150A]Turnigy Brushless Car Power System 2350Kv/150A[/link]
its listed as $189, but drops to $149.95 once you log in!
An extremely powerful brushless system for any 1/5 or 1/8 scale truck, car or buggy.
Equiped with cooling fan and a large surge ESC, this system will greatly increase the power output of any standard or brushed system.
ESC Spec.
Continuous Current: 150A
Burst Current: 1080A
Resistance: 0.0002ohm
Suitable Car: 1/5, 1/8 on and off road.
Battery: 2-6 cells Lipo (6-18 cells NI-xx)
BEC output: 5.75V/3A switch mode buit-in
Motor type: Sensorless and sensored brushless motors
Dimension: 68 x 55 x 45mm
Weight: 150g
Motor Spec.
Model: 3674SL V2.0
Kv: 2350
Scale: 1:8
Max Current: 76Amp
Turns: 9T
Weight: 363g
Diameter: 36mm
Length: 76mm
Shaft length: 15mm
Shaft Diameter: 5mm
Contents:
ESC: 1 x 150A
Motor: 1 x 3674SL (2350Kv) with Cooling Unit
Pinion Gear: 21T
Turnigy Programming Card
Very Tempting @ 149! i wonder if this will affect castle's pricing on the mmm?
ESC Spec.
Weight: 150g
Motor Spec.
Model: 3674SL V2.0
Kv: 2350
Scale: 1:8
Max Current: 76Amp
Turns: 9T
Weight: 363g
Diameter: 36mm
Length: 76mm
Shaft length: 15mm
Shaft Diameter: 5mm
Contents:
ESC: 1 x 150A
Pinion Gear: 21T
