Heli fuel in the MGT 8?
I've had a few 8's over the past few years, but got out of it and into nitro heli's. Well, I got sick of heli's and have my 8.0 being delivered tomorrow. My question is, can I run my 20% heli fuel in it? has 20% oil as well. Maybe that would help to keep the temps down since it's such a big engine?
RE: Heli fuel in the MGT 8?
8.0(8cc) engine is technical a converted heli-engine so i guess it would work, but 20%. i would use at least 25% nitro. i mix my 25% with 30%
It works. you'll have to retune all 3 needles however, or it'll like to stall. temps are fine - it's a hotter running engine anyways. i routinely see temps that would melt a smaller traxxas 3.3 for instance.
I haven't used heli fuel, but have used high oil content fuels (synth oil) with no ill effects. wasn't as "punchy" since the oil displaces methanol, but ran more predictably once tuned. I would not use a higher percentage of nitro + a high percentage of oil... displaces too much methanol... nitro is what creates the flashpoint for ignition, but methanol is what sustains the explosion. too low and it won't ignite, and too high and it will fizzle and stumble after ignition. Run a hot plug, btw with heavy oils... |
Well, I've been using what's left of my heli fuel. 20% Byrons Rotor Rage with 20% oil. Runs well thus far. Not too much tuning was required.
do you use OS#8 plugs?
Yes, I believe so. I have to verify.
im using os #8 plug it works very well
