MT 4.6 aftermarket wheels and tire suggestions
Hey guys....just purchased one and could use some suggestions on wheels and tires. Pro-Lines preferably...
Thanks! |
Originally Posted by Noah Racing
(Post 12010858)
Thanks! Mattster |
I ended up getting the Proline Trenches. Great tires.
Do you have any pictures of your new wheels/tires installed?
Thanks. |
Hope you are taping them ....mgt gots power so trenchers will balloon to about 9inches..
I have a set on my xtm mammoth,lst,pedes,sc10rs etc..the bigger guys got the trencher x and love them. |
What does everyone recommend? I'm open for suggestions. Right now I use the ones that came with my MGT.
Depends
Are you dirt only grass mud street gravel if yes trenchers but you got X and then you got standard. If you are hardcore off road badlands Some like big Joe's and they are ok.. They also make tsl swampers and they are gripy but sidewalls give out on the street on hard turns.. |
I run on a little bit of everything. I'd like something that will work alright on the street and work good off road.
Then get trenchers you'll be happy.
I just ordered some src terrain crushers since one of my trucks sees more road than grass..so I forgot about them but havnt used them yet |
I have mgt (thunder tiger mta4) and has 14mm hex hubs.How can I fit wheels with 17mm hex?
Originally Posted by 4kinitos
(Post 12500203)
this is an old thread so the original people may or may not come back to respond. either way i am sort of in the same boat, have one MGT with the 23mm hex adapters and the other with 14mm hexes. going to stick with the 14mm for now. let me know what you end up with! |
The main problem in mgt and thunder tiger s28-s50 with 14-23mm hex hubs is that universal shafts are 6mm thick.Also the hole of the shaft is way in and you can't fit hubs like this which are the most you can find..
https://cimg0.ibsrv.net/gimg/www.rcu...96f5e8a501.jpg https://cimg1.ibsrv.net/gimg/www.rcu...278b2b4ecd.jpg You can only use hubs like this. https://cimg9.ibsrv.net/gimg/www.rcu...879bf21e7f.jpg Part number is Integy C23101S.There are two options for different offset +6mm +12mm and two different colors.I chose silver +6mm because I didn't want to widen the truck. You need to use spacers inside the hub retainer to tighten because the washers come with are not thick enough and whole hub come out of the steel pin. I used Bushings 5x8x2.5mm (Traxxas 3775). https://cimg1.ibsrv.net/gimg/www.rcu...19c6a69259.jpg |
On those Integy hubs, where would you put the bushings?
Originally Posted by rabidfox50
(Post 12594700)
https://cimg5.ibsrv.net/gimg/www.rcu...de6d4f1290.jpg |
Got it. Many thanks. I have these ordered for my MGT restoration.
