RCU Forums
RCU Forums (http://www.rcuniverse.com/forum/)
-   Team Associated - Monster GT (http://www.rcuniverse.com/forum/team-associated-monster-gt-497/)
-   -   Mini Mgt 3.0 Upgrades??? (http://www.rcuniverse.com/forum/team-associated-monster-gt-497/8565384-mini-mgt-3-0-upgrades.html)
Sicmaxx55 03-10-2009 10:22 PM
Hey im picking up a mini mgt 3.0 this friday and i was wondering if there are any LARGE downsides that i should know about? And what upgrades should be bought for light bashing like small jumps and the occasional roll. One other question how hard is it to wheelie this truck?
ilanstylz 03-10-2009 10:27 PM
RE: Mini Mgt 3.0 Upgrades???
Some people have no problems making their 3.0 wheelie, but a few like me do....... I run my very rich because of the weather here plus I'm new to rc's so right now I'm trying to learn more how to drive them then wheelie them ;-)....... But with the right tune you should be able to wheelie them pretty easily...... As far as upgrades, maybe some bigger tires using either the 17mm or 23mm hex adapters........ The only downside that I've experienced and I've read others have, is the stock engine tends to overheat, so you want to watch how much you lean it out and check the temp every now and then........
Sicmaxx55 03-10-2009 10:35 PM
Thanks alot. While running your lean does it still run good? Because my savage and lst2 run strong lean or rich. Any random weak partS?
ilanstylz 03-10-2009 11:01 PM
It still runs good, and you will see the power difference..... I'm still learning to tune, so I don't want to risk having mine lean to much and do unnecessary damage to the engine....... I've bashed my 3.0 for over two weeks pretty hard, and so far the only thing that I've broken so far is the front bumper ring, which I dont feel is to important for me to worry about replacing anytime soon.......
sincityshooter 03-10-2009 11:10 PM
there pretty sturdy trucks.
Like ilanstylz said the bumper rings tend to break.. i broke a rear one but if they break there doing there job
Sicmaxx55 03-11-2009 12:33 AM
gotcha does anyone know where i can get some hop-ups for it?
sincityshooter 03-11-2009 12:48 AM
you can find aluminum parts on ebay i think integy(sp) makes them.. new era models sells a kit to put a big block motor in it
Sicmaxx55 03-11-2009 12:25 PM
i'd like to keep it small block and find a power house .18 to put in it. I want great wheelies on demand and still keep it around 37-39mph. A big block would be nothing put wheelies
sincityshooter 03-11-2009 02:20 PM
true, i like the stock motor, it smokes my friends mgt :D
scott36 03-12-2009 04:14 AM
if you add a set of new tires with 1/2 offset rims it will handle better and look cooler to. love mine.
breezerboat 03-12-2009 09:53 AM
Scott36, which rims and tires do you suggest? Would bigger tires help with wheelieing?
twomanytoys 03-12-2009 10:23 AM
I use Maximizer beedlock whels with 1/2 offset. They are awsome.
breezerboat 03-12-2009 10:41 AM
Holy Cheetoes!!! those things aren't cheap. What tires? What does 1/2 inch offset mean?
twomanytoys 03-12-2009 11:14 AM
1/2 offset means the wheels will set the width of the truck wider than stock. The center of the wheel where the hex is bolted is set 1/2 inch closer to the hub. Axial also makes good beadlocks. Yes they are not cheap but well worth it. You wont ever have to buy wheels again. No gluing and if you break a wheel you just replace the broken part for about $4.00 instead of buying a whole wheel. Pro line Badlands are one of the best tires you can get. Very agressive tread and awsome traction in any condition.
scott36 03-12-2009 01:47 PM
http://www3.towerhobbies.com/cgi-bin...7&I=LXTTD1&P=K
these are the ones i use and they look cool to. i dont think bigger tires will help with doing whellies tho.
scott36 03-12-2009 02:01 PM
1 Attachment(s)
here is a pick of full off set tires and rims, cant find the pics with the 1/2 off set put you will get the idea here, the truck mesures a full 17.5 inchs wide with full off set rims and tires.
breezerboat 03-12-2009 02:39 PM
GEEZE LOUIS!!! That thing is wide. And do you ever drive it? It's clean as new and no scratches.
scott36 03-12-2009 03:40 PM
yep i do drive it , its been winter here so getting dirty is on the summer list of things to do.
jologs 03-13-2009 10:14 AM
hey guys, i'm planning to change the stock engine to toki .27. Any suggestions???
jermainezey 03-13-2009 03:44 PM
am new to rc nitro and i have the mmgt 3.0 i been using traxxs top fuel 20 per cent and my truck dont over heat no more now have lean it out and it have all sort of power and does wheelie easy
sincityshooter 03-13-2009 04:18 PM
Quote:
ORIGINAL: jologs
throttle control:D
jermainezey 03-13-2009 08:45 PM
what kinda fuel do u use in your 3.0
twomanytoys 03-13-2009 08:54 PM
Quote:
ORIGINAL: jologs
You dont want a toki engine. Yuck! [:'(] Get a better mill. You want great low budget power then look at a Sportwerks 26v2 or 21v2. Best engine for about 120.00. The Toki will not last long and have heat and air leak problems.
kuade 03-14-2009 09:45 PM
I can kind of do wheelies if i take out the front drive axles....
Sicmaxx55 03-16-2009 01:50 AM
I run 30% trinity monster horsepower fuel and i run it rich my motor stays cool around 220 and will wheelie almost on demand. Very good set-up.
