Team RCU - Don Szczur Ask your questions directly to Don Szczur, proffesional pattern pilot
Snap Roll and Rolling circle flight modes
Reply
Old 08-21-2005, 10:15 PM
apereira
apereira's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Snap Roll and Rolling circle flight modes
Hello Don I hope you can help me on this,
I have a Snap Roll flight mode in my 10X, is this a good idea?, how will you set this up or trim(ATV) to get a good snap roll without loosing the heading?, also is it a good idea to have a flight mode for the rolling circle?, I mean, to have enogh aileron to keep the stick at full deflection to get the desired roll rate and just to worry about rudder an elevator?
Thanks alot
apereira is offline
Old 08-22-2005, 09:43 PM
Don Szczur
Don Szczur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Snap Roll and Rolling circle flight modes
I've done both. Ideally, you'd want just one flight mode for everything, but it depends on the aircraft design. For example, on my Focus, it would not snap well, do a hammer head well, or rolling circles well on just one rate. I had a rate for standard flying, a rate for snaps, spins and hammer heads, and a rate for one-roll circles and one-roll loops. The rolling circle rate was just for extra rudder, but the same elevator and ailerons as standard rate, to help with the one roll circles. The snaps, spins and hammer heads were for those manevuers, with expo increased on those flight modes to give the same feel around neutral. I could, for example be in the middle of a loop (just before an avalanch) with the elevator deflected, and perhaps some rudder in to correct for a cross wind, and hit the function switch and the plane would not jump with any difference in throw as compared to the inputs that were in place when I put the switch on. The toughest part about this setup is switching the rate switch at the end of a one roll circle from inverted. Its tough reaching for the switch when you have negative stick deflection entered.
Now the Brio, for example, is completely different. It has a lot of ruddder authority in standard rate, so I don't need a separate switch for hammer heads and one roll circles. I use one rate for them which is the same as regular flying rates. Same flying rate is good for one roll rolling loops also. I do use a separate rate for snaps and spins, but I'm right on the bubble, as the plane will do vertical down snaps on low rate for example. I still use the higher rates for more defined snaps. Its worth a point or 2 (or 10 in some cases).
CHeers,
Don
Don Szczur is offline
Old 08-24-2005, 12:10 PM
apereira
apereira's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Don, thanks for the explanation, y guess it is better just to find the right set up to minimize the used function and concentrate more on the maneuvers, and now that you talk about the Brio, I want to get a new 2m and I'm trying to decide between the Brio and the Impact, any comment that you might make will be of great importance in my decision, I'm thinking about the P07 and on, and the Brio has more frontal area which should help in P07 in order to fly a little slower and have more time for the maneuvers, what do you think about them.
Thanks!!
apereira is offline
Contact Us Archive Advertising Cookie Policy
