Team RCU - Don Szczur Ask your questions directly to Don Szczur, proffesional pattern pilot
BRIO ENGINE OFFSET
Reply
Old 01-22-2007, 12:25 PM
F.Imbriaco
My Feedback: (56)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default BRIO ENGINE OFFSET
Hi Don,
Do you have knowledge of the engine degrees of offset ; right and down Thrust on the Brio ? Haven't been able to find it in print or in your Brio by the numbers.
F.Imbriaco is offline
Old 01-22-2007, 10:45 PM
Don Szczur
Don Szczur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: BRIO ENGINE OFFSET
I don't have numbers and believe it would be difficult to measure, unless its with respect to the wing incidence. I recoommend using the spinner ring as a reference mark. The plane needs slightly less right thrust from the spinner ring if you run 2 or 3 blade props, and its pretty close for 4 blade props. Plane needs just a little bit (1/16 inch down thrust) with respect to the spinner ring. Again, no measure and I may have tried to measure at one point but again but found it to be inaccurate with respect to the fuselage (there are no straight lines on the fuselage to measure from. Best of luck and the plane flies great in this configuration.
Don
Don Szczur is offline
Old 01-23-2007, 06:29 AM
F.Imbriaco
My Feedback: (56)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks for your input , Don. I'm looking forward to a good Spring and successful test flights. Appreciate your efforts with the construction by the numbers on this forum.
Old 01-23-2007, 09:39 PM
MTK
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Frank, let's talk. I've designed and built a simple device that you can use directly to measure engine offset. It requires that your wing is level but that shouldn't be too difficult to get.
Matt
ORIGINAL: F.Imbriaco
Hi Don,
MTK is offline
Contact Us Archive Advertising Cookie Policy
