Team RCU - Don Szczur Ask your questions directly to Don Szczur, proffesional pattern pilot
Control Linkage
Reply
Old 09-26-2007, 06:31 PM
KGSS28
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Control Linkage
Hay Don I was wondering , I was looking at your Brio in Huntsville it looked regular clevis hookups and not ball bearing stuff . Am I correct and what are you thoughts on the differences in the two types ?
Thanks Kirk
KGSS28 is offline
Old 09-29-2007, 10:25 PM
Don Szczur
Don Szczur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Control Linkage
Simplicity.
It works reliably,
Easy to set up and make changes,
Cost is minimal.
See you,
Don
Don Szczur is offline
Old 09-30-2007, 02:16 PM
KGSS28
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Kirk
KGSS28 is offline
Old 10-01-2007, 01:57 PM
stek79
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Very interesting question Kirk!!!
May I ask what kind of clevis did you choose Don? Nylon, metal? Product name?
Some time ago I was in the process of choosing them too, and finally I decided for some standard ball bearing end points... I left the expensive MK stuff on the shelf!
stek79 is offline
Old 10-02-2007, 07:07 PM
Don Szczur
Don Szczur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, I used Du Bro nylon but after 2 seasons they have developed some slop, so I plan to replace them with either nylon or the expensive bb kind...
If you use nylon, be sure to use a keeper/tubing to keep it tight against the linkage. That is where the strength is.
Don
Old 10-03-2007, 12:55 PM
stek79
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Thanks Don
If I understand correctly, some little play will not affect the airplane trimming too much, am I right?
That would be an interesting consideration, since it proves that we don't need all the top quality accessories to reach a good performance.
Bye Don!
stek79 is offline
Old 10-03-2007, 03:42 PM
KGSS28
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
About how many flights will you make in two seasons? I bet a lot more than I do. Mine may never wear out.
Kirk
KGSS28 is offline
Old 10-03-2007, 11:03 PM
Don Szczur
Don Szczur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Understand I split my flying between 3 airplanes in the last 2 1/2 seasons. The yellow one that had BB linkages took the brunt of my flying. I probably put 60 or 70 gallons though that plane. Maybe 500 to 550 flights and the bb links have some play in them. The two other Brio's I probably have between 75 and 100 flights each. I took the linkages off the elevators tonight and they are ok. Worn slightly but ok. I'm replacing them with new link/horn and control clevis, both plastic now with no slop.
Old 10-03-2007, 11:09 PM
Don Szczur
Don Szczur's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ID:	776195   Click image for larger version
Old 10-04-2007, 01:09 PM
stek79
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Great Don thanks!!!!!!!!!
Really good info.
stek79 is offline
Contact Us Archive Advertising Cookie Policy
