Rudder throw: how much for pattern?
Hi Don, as usual thank you very much for the time you spend answering to our novice questions!
Several days ago I have started to set up my small depron airplane in a pattern-oriented way, in order to fly more precisely and possibly partecipate at local electric pattern contests. I have to say that after much time spent trimming it up I have reached an amazing (for me!) result: the plane flies precisely with good KE and rolls capability with very little couplings, despite its 3D surfaces and its light weight! In particular, I have spent much time with rudder (and elevator) D/R and EXP and now it really suits me well. Now, I would like to find a more systematic way of determining good rudder throws and EXP: for example, I found that my plane holds KE with about half rudder stick (at half throttle). Do you use some criteria like this when you set up throws and exp on a new plane? Or you think that these are very subjective topics and trial-and-error is the only possible process? Thank you again, good flights!!! Stefano |
RE: Rudder throw: how much for pattern?
I agree with your setups. The onlyl difference is I use a second dual rate mode for one roll circles which provides extra rudder and elevator throw. Sounds like you have it optimized!
Don |
