ultimate wings
IL
ultimate wings
I am scratch building a 42% ultimate from Godfrey plans.The question I have is it calls for 0 degees onthe wings and +2 on the stab.Is that going to do the same as negative in the top wing?What is the best way to set it up.
Thanks, Todd
Thanks, Todd
IL
RE: ultimate wings
What kind of wieght should I be looking for with out motor and radio gear?Do you think the flying wires are a must on the wings?What can I do to not have to put them on?
Thanks, Todd
Thanks, Todd
RE: ultimate wings
I know my Ultimate weighs about 40 RTF, so youd have to back out a DA-150 w/ prop and mufflers and the radio gear. I dont really have a clear answer for you.
On the flying wires, I dont know how the wings are built so I cant say. Assuming the wings are strong and it uses a 1-1/2" tube in each wing, it should work w/o wires.
IL
RE: ultimate wings
The wings are foam with the leading and trailing egdes sheeted and cap strips.I could only fit a 1 1/4" wing tube in the wing without it getting to thin.Thanks for all the help!!!
Todd
Todd
