35% Extra 260
#153
My Feedback: (9)
IN
RE: 35% Extra 260
Hey Mike
Have a bunch of flights on the new 260. The problem I'm having is that it flies to straight.
I'm not used to this from an ARF and is there any cure?
Thank you for your time.
Great Plane and a Great Value.
Next time your up at Wheeler I'll let you fly it.
#156
RE: 35% Extra 260
Hello Mike,
My name is Fernando, I am from Brazil,
I bought here an Extra 260 35% and I am installing an engine DA100 and want to know about canister System, which components I buy.
I am placing the items below., Is correct?
Items
MTW TD75
25mm dia/70mm drop
2-Teflon Coupler and 4-Clamps.
Sorry, I don´t speak english very well
Fernando
Items
MTW TD75
25mm dia/70mm drop
Fernando
#157
RE: 35% Extra 260
The Cans I believe are the MTW 75K. They are the front exhaust ones that are longer and thinner diameter (55mm).
I dont remember how the header drop is defined. The drop needed as measured from the mating face of the header and cylinder to the center line of the coupler is 54mm.
If you talk to Desert Aircraft, just tell them its for the H9 35% 260 and they'll know what you need.
You also need 2 couples and 4 clamps.
#158
RE: 35% Extra 260
ORIGINAL: grind2tenths
Mike , Will the MTW 75's in the K series (stubby version) fit the pipe tunnel without much modification? I already have these silencers and would like to use them .
