TEAM RCU - Mike McConville Ask expert Team RCU pilot Mike McConville questions in this forum.
H9 35% 260 Stab Tube Bolts
Reply
Old 10-24-2007, 02:34 PM
camss69
camss69's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default H9 35% 260 Stab Tube Bolts
Mike,
I'm finishing up my build on the plane and drilled the stab tube last night for the bolts. It says in the manual to use a 1/8" drill bit, which I did, but after doing so it's a pretty loose fit since the bolt is so much smaller. Is that the right size? Seems to me there is quite a bit of play, I notice in the manual it says 1/8" bit or (3mm) which there is a pretty big difference there. I'm just wondering if that's how it's supposed to be because the only thing keeping the stabs tight from sliding in and out 1/16" or so is that bolt going into the fuse now.
Thanks!
Nick
camss69 is offline
Old 01-08-2008, 08:13 PM
tailskid
tailskid's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: H9 35% 260 Stab Tube Bolts
Could you tap it for a 6-32 bolt?
tailskid is offline
Old 01-08-2008, 08:59 PM
MMcConville
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
No, there is a 4-40 b-nut set in the stab. The hole in the tube just needs to be a thru hole for the 4-40 bolt. I'd rotate the tube 90 degrees and drill it again with a smaller bit. Whatever is appropriate for a snug thru hole.
MMcConville is offline
Reply
Display Modes
