If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 3 of 3
Thread: 35% 260 Cans
  1. #1
    Join Date
    Oct 2002
    Walnut Cove, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    35% 260 Cans
    Mike will the MTW's (75) 70 mm diameter cans work with the 35% Extra these are the short canisters. I think they are the 70mm vs the 55mm version. Also are the servo bays enlarged for 8611s and 8711s or will the standard 8411 drop right in with enough meat for the screw to grab with the standard 8411 case. Just trying to settle some issues before setteling on the plane. Thanks Grind
  2. #2
    Join Date
    Jun 2003
    Champaign, IL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 35% 260 Cans
    The mounts will have to be removed since they are made for the smaller diameter cans, but the area should accept the larger can with the addition of a new mount for them. Looks like there is approx 93mm of vertical space for the cans.
    The servo opening will accept an 8611/8711, but an 8411 should be ok. The servo opeings are 22mm x 41mm.
    Mike McConville
    Horizon Hobby
  3. #3
    Join Date
    Oct 2002
    Walnut Cove, NC
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: 35% 260 Cans
    Mike, Got the plane looks great. Took one of the DA 150 70 mm canister mounts and trimmed 1/4 off of the sides and a 1/4 in. off the top and placed the top of the monunt against the bottom of the rear of the pipe tunnel top. and didn't have to cut anything. The K series pipes are about 3 in shorter and didn't get to the built in mounts that are already there. There looks to be about 5/8 in clearance aroud the pipes on all sides. I am going to make a vented plate to go on the bottom of the fuse directly under the pipes for cooling. I will post pictures when I have it all together. Thanks grind
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
