HELP WITH THE 9303 AND 4 SERVOS ON WINGS
HI MIKE, IS THERE A WAY TO PROGRAM ON THE 9303 2 SERVOS ON EACH WING AND FOR THE TRIMS TO WORK NOT ONLY IN TWO BUT IN ALL FOR SERVOS, ALSO WHEN I MIX RUDDER TO AILERON TO COMPENSATE ON KNIFE EDGE ONLY ONE WING RESPONDS TO THE NEW MIX. I REMEMBERD THAT ON THE 7 THE LAST MIXES INCORPORATED THE TRIM FEATURE BUT APPARENTLY THE 9303 DOES NOT, CAN IT BE DONE WITH OUT ADITIONAL MATCH BOXES?
THANKS
LAZETA
THANKS
LAZETA
