46% ultimate engine incidence
Mike, my hangar 9 ultimate is fantastic,I have followed assembly according to instructions and addendum but when I do a vertical upline the plane wants to go to towards the canopy, I have a DA 150 on the nose, and with bottom wing at 0 and top wing at -1, tail plane at +1, engine firewall and engine are at +2, is this right?, if not do you recommend washers or moving the engine higher?, also a little nose heavy at 9 1/8, so I tried 9 5/8 and still feels nose heavy, how much more would you suggest, if I should move it furder? thanks.
