Ace SkyTech TSi receiver compatability
FL
So I'm going to buy a used Trex 450 Pro that needs a receiver. I have a SkyTech radio that came with my Raptor and will work just fine for me at my current skill level. What receivers are compatible with this transmitter? It's a 2.4, so I'm not sure about the compatibility stuff. I'd like to go with something smaller so it will fit inside the frame, as opposed to mounting it on the outside of the frame. Thanks.
FL
RE: Ace SkyTech TSi receiver compatability
That's what I'm finding. I called Hobbico and they don't have a lot of info on what might be compatible right now. I went with a new Spektrum DX7 since the 450 already had a JR rcvr in it. I'm going to use the Skytech for my airplanes and convert my Raptor to a JR rcvr so both helos are on the same radio. What I found was most transmitters are only compatible with the same company rcvrs.
The Ace Sky Tech is a re-branded Hitec Optic 6. If you look at the back of the transmitter at the FCC id you'll see that it says Optic 6 in the id. You should be able to use any Hitec 2.4 receiver.
