If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 5 of 5
  1. #1
    Join Date
    Sep 2007
    greenville, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    raptor 50 v2 problems
    hi everyone, i just bought my first raptor 50. it was allready built but is new, question about blades, book says they use 600mm but this one has carbon fiber blades that are 650 mm. is that going to cause the heli to wag back and fourth and spin faster when you excelerate. i just dont see anything that is wrong with anything else. also, does any body have the same set up with radio and gyro. im useing a hitec eclipse 7 with a gy401 gyro. what should the settings be at for hover mode and the other ones. please help, sorry, also what would cause a rattle noise when starting to spool up but then stops after the blades are moving. thanks
  2. #2
    Community Moderators BarracudaHockey's Avatar
    Join Date
    Jul 2003
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: raptor 50 v2 problems
    Belt loose is probably causing the noise.
    The Raptor should have 600mm blades, are you sure they are 650?
    http://www.raptortechnique.com has a ton of info on radio setups. Tail wag is a gyro problem
    Andy - RCU Community Moderator
    AMA 77227 Leader Member- Contest Director
    www.JaxRC.com
  3. #3
    Join Date
    Sep 2007
    greenville, MI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    thats why i was asking about the radio set up. i have looked at that site but it dont show that radio with that gyro. so will them blades cause a problem or not.
  4. #4
    Join Date
    Sep 2010
    Soldotna, AK
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Those blades could cause a blade strike with the rotor blades a 50 shouldnt have more than 600mm blades unless it is a titan 50 se then it could have 620 mm blades
    measured from the blade bolt hole
  5. #5
    Join Date
    Oct 2005
    Yellowknife, NT, CANADA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    I see this is an old thread, but the pin backing out of the tail pulley can cause the rattle/clicking noise similar to the belt.
    Cub Brother #10
    Waco Brother #221
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
