Raptor 50 Hitec servos?
Reply
Old 04-24-2012, 12:56 PM
Aviator 25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Raptor 50 Hitec servos?
When I first came here last year to ask about buying my first nitro heli a Raptor 50 Titan I was told that the Hitec HS425 servos I was using would get me by well I was getting to know my new heli, But that at some point in the near future I should look at getting better servos. So here I am looking at up grading.
I've done some searching on the net for info on servos for 50 sized helis and I find it somewhat confusing. Much of the info I find seems to be old and out dated recommending servos no longer available. Also I come from the old school (early 90s) of flying rc planes, I'm not up on all of the new tech. I know that everything is digital servos now days, but what servo do I pick? My LHS keeps a large selection of Hitec servos in stock and my radio is Hitec so I would like to stay with Hitec. Is digital the way to go?
Here are a few servos I was thinking about.
HS-5625MG
HS-7966HB
HS-7975HB
Are any of these a good choice?
I don't need a tail servo as I am running a 401 gyro with a S9254 servo. My heli is running a 6V battery (with gyro regulated).
Thanks.
Aviator 25 is offline
Old 04-24-2012, 01:04 PM
BarracudaHockey
Community Moderators
BarracudaHockey's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Raptor 50 Hitec servos?
Personally, I'd get Align DS610's
I've used 5625's in 50's and they are ok, and at your flying level probably just fine but the 610's will keep you from upgrading again later on.
Either of the other two choices would work as well if you're not thumping on it. I can tell you that 5625's will get sloppy after a while which I dont like for helis.
BarracudaHockey is online now
Old 04-24-2012, 01:49 PM
hsmythe
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
+1 on the DS610s I have them on my Trex'. . I've also had good luck with Futaba S9252's on both my Raptor 50's and my Raptor 90SE. Of course, I'm sure I don't push them as hard as Barracuda. I fly like an old man, because I am one.
hsmythe is offline
Old 04-24-2012, 05:47 PM
Aviator 25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I will have to ask my LHS if they can order in Align DS610 servos. Is there any good places to order them online for a good price? If I decide to go with the DS610 can I simply remove the HS425s and install the DS610s without changing any of my radio setup (program settings)? I like the way I have the heli setup now and don't want to have to reset everything. I was hoping to just pop off the Hitec servo arms and put them on the new Hitec servos, but I'm guessing I can't do that with the Align servos. Though I don't see it being a big deal installing the new Align arms as long as I set it back in the same spots. I just don't want to have to change all my radio setting. Though I do understand I may have to make some small adjustments to my trims.
Old 04-25-2012, 12:59 AM
spog1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The Hitec 5625's get sloppy quickly because of the metal gears. The hitec carbonite servos work very well in the raptor.
spog1 is offline
Old 04-28-2012, 08:27 AM
Aviator 25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
BarracudaHockey the info you gave me in the past made my Raptor turn out to be a huge success. From the heli, to the engine, to the gyro it just works perfect. My LHS can order DS610 servos so if you say they'er the way to go then that's what I'll do.
Thanks again for the help.
Old 04-28-2012, 12:41 PM
BarracudaHockey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Always happy to help.
Old 04-30-2012, 06:04 PM
Aviator 25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Oh, one more question. I have Radix CF main blades on my Raptor 50 Titen and I wan't to get matching Radix tail blades, what size do I need to get? will I have to do any changes to my heli after installing them?
Old 05-01-2012, 04:46 AM
BarracudaHockey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
92mm but I don't like them, they are very thin airfoiled and I tore up a couple sets just touching grass. I prefer Edge
Old 05-01-2012, 12:27 PM
Aviator 25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't mind getting the Edge tail blades if you say they'er good . Is using CF tail blades a bad thing? Should I just be sticking with the stock blades or is it just the Radix blades that are a problem?
Old 05-01-2012, 12:34 PM
spog1
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I like to use raptor 60 tail blades (pv0163) and cut them down for improved tail authority.
spog1 is offline
Old 05-02-2012, 04:50 AM
BarracudaHockey
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
They are stiffer so tail response is generally improved. I've also had problems with some plastic tail blades where the bolt hole can wallow out from the screw and cause vibration.
The only ones I had an issue with were the Radix. They flew great but were too delicate for me.
Old 05-03-2012, 09:30 AM
Aviator 25
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I'll get the Edge blades.
Thanks again.
Reply
Display Modes
