If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 7 of 7
  1. #1
    Join Date
    Apr 2007
    Schweinfurt, GERMANY
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    un-explained crash??? (Explained)
    Β*So after upgrageing to an OS50 and all the necessary parts to take a 30 to a 50... i went to fly... The OS fired right off with no problems. I then took the rotor up to speed keeping it firmly on the ground. I tested the tail and it responded just as it should. Β*Then I went to make it light on the skids to test the other controls. As it became light it just started to go to the right and didnt respond to my input what so ever. The throttle was still responding normally, so as it went onto its side i was able to kill the engine to prevent even more destruction... So my question is what could have caused this? I checked my swash and its completly level the trims are centered (Futaba 9c). When I replaced all the parts I had the entire frams apart (to clean it good) and the head was also taken off. Is there something i forgot? Im about to order the parts I need and Want to know if there is a part I overlooked that needs replaceing or possible causes I can look into. Thanks Β*
    Raptor 30 V2
    Futaba 9C Super
  2. #2
    Join Date
    Feb 2002
    Visalia, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: un-explained crash??? (Explained)
    Did the swashplate direction correctly respond to transmitter input? I know this is a basic question but we have all had a reverse control situation no matter how many times we look and check.
    Obviously you have heli experience so something simple has occured here. Could be reverse control or a servo going bad due to vibration.
    It is spooky when you cannot find an obvious problem.
    Dick Tristao
    ModelGrafix
    Visalia, Ca.
    559 625-3590 Home/Office
    559 280-6559 Cellular
  3. #3
    Join Date
    Apr 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    ill check it : never know. thnks for the tip im ordering parts and checking my radio when im off work
    Raptor 30 V2
    Futaba 9C Super
  4. #4
    Rafael23cc's Avatar
    Join Date
    May 2002
    Junction City, KS
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    If you disassembled the frames when upgrading the engine, I would suspect that you forgot something when re-assembling the helicopter. I will concentrate my search on the aileron servo and related components as that is the one that showed signs of failure, but a good check of all the controls should be in order.
    Rafael
    Keep your eyes on the sky but your feet on the ground!
    Team Heliproz.com / AMA # 8109
  5. #5
    Join Date
    Apr 2007
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Ok,
    someone can change the name of the thread to "explained crash"..... Im sooo pissed now to know it was completly my fault. the swashplate direction does not respond correctly...... In fact its backwards on both directions..... *** So thats a Nice pair of Carbon blades in the trash because I didnt make a basic check.... O well live and learn.... atleast I know what I wont do next time..... now time to go kick myself a few times
    Raptor 30 V2
    Futaba 9C Super
  6. #6
    Community Moderators BarracudaHockey's Avatar
    Join Date
    Jul 2003
    Jacksonville, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    All fixed
    Sorry to hear about it, the good news is, you probably won't make that mistake again.
    Andy - RCU Community Moderator
    AMA 77227 Leader Member- Contest Director
    www.JaxRC.com
  7. #7
    Join Date
    Feb 2002
    Visalia, CA
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    And my rump still hurts from the self kicks!!
    Dick Tristao
    ModelGrafix
    Visalia, Ca.
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
