Newbie seeks blade advice for a Raptor 50
NT, CANADA
RE: Newbie seeks blade advice for a Raptor 50
I almost second that. Wood blades don't track very well, but may be the best choice if you are still learning to hover and even first transition to forward flight. Metal components and carbon blades can add up pretty quick learning to hover/fly. I'm hoping you have someone helping you, or at least have mastered the flight sim before trying to hover the real thing?
NC
ORIGINAL: Lins
I agree !
But these are actually only $6 more then the TT Wood Blades
http://www.heliproz.com/Mavrikk-2Q-P...ctinfo/822141/
I use Mavrikk carbons on my 60v2, I'm just a little further than you on the learning curve and they work out great. I recommend Heliproz as well too.
If you haven't done yet, get some really long 3/8-1/2 wooden dowels notch in the middle so they make a perfect x and zip tie to the landing skids, with plasic balls on the end (somewhere in the 2" diameter area). That should help a little. The training gear really helps me not tip over on takeoffs and landings. While it doesn't look the coolest it saves money on blades.
I took the wooden blades that came with mine and threw them in the trash they never went on my heli. The Mavrikks do track very well.
