Current draw on Rap 30
Reply
Old 04-28-2013, 06:07 PM
123Cat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Current draw on Rap 30
What would be the current draw for servos and gyro so I can put that load on my RX battery to test its voltage
thanks heaps
123Cat is offline
Old 04-29-2013, 02:53 AM
highlander84
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Current draw on Rap 30
A few problems, what servos and gyro and receiver are you running. They all draw diffrent currents (IE the tail servo is diffrent from the others). Also, while under load the servos draw more voltage than when idle. The best way to test the voltage is to use a volt meter while its powered on. Then you could see the draw on the battery while all is connected. Hope that helps.
highlander84 is offline
Old 04-29-2013, 01:50 PM
Rafael23cc
Rafael23cc's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: 123Cat
thanks heaps
What battery chemistry are you using? Nicd, nimh, lipo, life, or liion?
It was a good rule of thumb to use 0.5amp load on a nicd or nimh battery to give you a good indication of "working" voltage.
It is also a good rule of thumb to use a 1.0amp load on a lixx type of battery to give you a good indication of "working" voltage.
It is understood that just like power packs, you need to heed by the 80% rule on rx packs if you are using lixx type of batteries, not just voltage reading.
I hope that helped you in your search for the answer.
Rafael
Rafael23cc is offline
Old 04-29-2013, 02:51 PM
123Cat
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Its the Eneloop 2000 Mah pak
that would be Ni metals
Thanks I will put on a 1/2 amp load
123Cat is offline
Reply
Display Modes
