Tt 70proh(r) engine
Old 08-25-2013, 08:22 AM
PBR
Default Tt 70proh(r) engine
Can someone please give me the settings for the main needle as well as for the mixture metering (bottom) needle. I use Coolpower 15% fuel. I live approximately 5000 meters above sea level.
The engine has started cutting out after a colleague at the field set on the engine. She idles fine but cannot get over 1/3 throttle. Here she will splutter and then die.
I have run out of ideas. Any help will be welcome.
