RAPTOR engine head temp. OVERHEATING??
ON, CANADA
what would you say is a good head temp as compared to a overheated condition? say for example is 124deg f & crank case temp of 106deg f good (measured about 35 sec after shutdown)
ON, CANADA
RE: RAPTOR engine head temp. OVERHEATING??
so if my engine head temp is in the 140s, then maybe i should lean it out a bit more. it quite on me in idle
