Gyro 611 ???? Help
RE: Gyro 611 ???? Help
Plug the servo into the gyro and the gyro into the rudder channel.
Now you need to set up a channel thats controlled by a toggle switch and you can set the end points on. I have no idea how to do that on that radio but you need to plug the other wire coming from the gyro into it.
Tinker with the end points in the radio till one side of the switch the readout on the gyro says A35 and when you flip the switch it says N35.
Fly it where it says A35
Set the end points in the gyro itself to something around 100 and so there is no binding in either direction.
http://www.jkheli.com has some setup stuff on the 601, its the same gyro for the most part.
DO NOT RUN OVER 37 to 40 percent gain or you will fry the (very expensive) servo.
