Programming a DX7 on a Raptor 50
My Feedback: (73)
If anyone could help out in this situation I would appreciate the help greatly. I am switching everything over to Spektrum and when it comes to the Govenor mode on my Raptor 50 the book says nothing about how to program this. I am hoping it will be an easy fix, but I hate to just dive in if someone has been doing it already.
RE: Programming a DX7 on a Raptor 50
There's no governor menu in the DX7.
Set the end points on the control channel switch to get your normal and idle 2 setup then use the sub trim to get the middle position set up.
I think Mike at RT has a DX7 so he's probably got some programming pages. http://www.raptortechnique.com
http://www.raptortechnique.com/review-dx7.htm
That's how Mike did it. It's kinda hard to find on the site
About half way down the page there's GV-1 how to.
My Feedback: (73)
Thanks Neriyah. Raptor technique knows it all! I set it up tonight just as he showed and everything looks perfect. Only one downfall with the DX7, there no 8th position to put an on/off switch for the govenor. I will just set the normal flight mode up for no govenor, he showed how to do this also. Thanks again and happy flying![8D]
I had to program mine to just use two head speeds and normal mode is gov off. I sometimes wish that I had waited for the x9303 too. Oh well, at least I am flying and don't have to worry about frequencies. [8D]
My Feedback: (73)
Just to set anyone else straight that reads this, I now have govenor mode on all three flight modes. The GV-1 govenor has a mode just for this type of transmitter. You can have the govenor turn on after 20% of the throttle stick is reached in normal flight mode. This way when you reduce the throttle on landing the govenor automatically shuts off below 20% stick. After flying this way I tend to like it more than having the on/off on a seperate switch.
One big thing that threw me for a loop for a few minutes is the trim system in the DX-7. When you trim normal flight mode out then go into advanced flight modes the trims return to center! You must trim each flight mode seperately.[:'(] That was a surprise the first time I hit the flight mode switch!
Edge_pilot, about your trims. If when you trim out your heli by the radio, then go into another mode and the trims go back to center, and your heli acts crazy, you did not trim your heli's cyclic very well mechanically. You should use very little trim if any at all on your radio when you fly. You should trim your heli mechanically on a 0 wind day, so it hovers level with a very minimum amount of stick input to keep it steady, no trim or subtrim added. The only time you would use the trim, is to adjust for wind. But I dont even use trim for that. Of course, this does not apply to the throttle.
ORIGINAL: edge_pilot
On the trim issue, I chose to buy a DX7 and not get 2.4 modules for my Futaba 8U because of the trims only working in normal mode on the Futaba. On the Futaba, when you go to Idle Up modes the trims don't work. You have to either work the mechanical setup or use offsets either of which require more effort than simply moving a trim switch. I love my DX7 although as I said above, I wish I had waited on more channels. Have a great day all. [8D]
I can see where that would be a problem. Glad you mentioned it so I don't get caught by that one. I don't normally boot the gyro in normal mode however I have learned to never say never as some days I tend to have brain cramps and I certainly might do it one day. It's funny how things change as we get older. I also don't trim the tail in any of the flight modes since I fly in HH.
Have a great one. [8D]
FL
Hmmm - I'm not familiar with the GV1 set up, but I'm using a TJ Pro gov, and I have my DX7 set up as follows.
The Aux 2 switch is the master on/off switch for my gov. The flight mode switch changes between 3 rpm settings. Normal is 1550, Stunt-1 is 1800, and Stunt-2 will end up becoming 2000 when I get my Carbon Blades - for now it's slightly more than 1810.
How exactly are you controlling your GV-1? My TJPro runs on a single channel to control the gov. Anything below 20% throttle - or anything below 5% on my AUX channel disables the gov.
My set up was really simple. I used 3 mixes. For any of these mixes to work - the AUX2 Switch must be up - with it down - the output to the AUX2 Channel remains at 0 meaning gov is disabled.
Mix1 ((((((Brings Speed up slightly above stunt 1 settings - [[[[Stunt 2]]]] )))))))
AUX2 > AUX2
+5%
0%
SW: F-S2
Offset: 0
_________________________
Mix2 (((((((((((((((Sets Aux2 Channel output for headspeed of 1800 - [[[[STUNT 1]]]] )))))))))))
AUX2 > AUX2
+65%
0%
SW: ON
Offset 0
Mix3 ((((((Reduces the Aux channel output to command a headspeed of 1550. [[[[Normal Mode]]]] ))))))
AUX2 > AUX2
-20%
0%
SW: F-NR
Offset 0
AUX2 > AUX2
+5%
0%
SW: F-S2
Offset: 0
AUX2 > AUX2
+65%
0%
SW: ON
Offset 0
AUX2 > AUX2
-20%
0%
SW: F-NR
Offset 0
