Go Back  RCU Forums > RC Helicopters > Thunder Tiger - Raptor 30, 50, 60, 90
Reload this Page >
Head shims on OS 91, necessary?
Old 12-01-2007, 05:44 PM
ftjets
ftjets's Avatar
Default Head shims on OS 91, necessary?
I was advised to add the provided head shims on my OS 91 SZ-H hyper w/pump when using 30% nitro. I forgot and have already installed the engine. Should i remove the engine and install them? I probably know what the answer is but you know i had to ask. [&o]
Old 12-01-2007, 07:59 PM
BarracudaHockey
BarracudaHockey's Avatar
Default RE: Head shims on OS 91, necessary?
With 30 percent, I would or you risk pre-ignition, which in the long run will be harder to fix than dropping the engine and sticking a shim in there.
Old 12-01-2007, 08:50 PM
ftjets
ftjets's Avatar
Roger that. Somehow i knew that would be the answer but i had to ask. Thanks for the advice. On the other hand, one hobby shop only had 30%. If i was able to find 15%, would i be safe? I will be doing much hovering and basic forward flight for awhile. I really don't need max power. Or should i just bite the bullet and get it over with?
Old 12-02-2007, 08:09 AM
BarracudaHockey
15's fine the way it is but make sure its heli fuel or has atleast 18 percent oil.
Old 12-02-2007, 09:55 AM
ftjets
ftjets's Avatar
I thought about it and can't imagine why i settled for 30% just because it's all they had. I'll return the 30 and order 15%. I've always flown with 15% heli fuel and had plenty of power for my flying. Can't imagine doing the 3d thing for awhile. Thanks for the help.
