Rabid Raptor
Rabid Raptor
I have no other way to describe my heli as a rabid raptor right now. I have a Raptor 50v2 with an OS 50 Hyper and JR 9303 radio. When I start the thing up the the clutch engages and it goes at full throttle. The clutch liner is stripping and i won't stop untl I turn off the radio. The radio, I believe, is set to where it is supposed to be so I am just very confused as to what is going on. I am by no means a veteran with this stuff so any ideas suggestions is appreciated.
RE: Rabid Raptor
1 Are you sure you don't have the throttle servo reversed?
2 What's your throttle curve look like?
3 With the engine off (but radio on) does the throttle arm moves when you move the stick?
If all the previous look correct make sure the carb is at idle when your stick is all the way down. Check the throttle end points.
Just some ideas[)]
Fernando
Just some ideas[)]
Fernando
VA
RE: Rabid Raptor
Look at the side of the carb by the throttle arm. There is a mark on the barrel and some marks on the carb case. When the marks line up at 12 o'clock the carb is closed, when the marks line up at 9 o'clock it is wide open. The arm moves counter clockwise to open the throttle. Make sure you are in normal mode. To correct your previous post, the engine goes full throttle then the clutch engages. And you stop it by turning off the radio????? You sound like you tried starting it more than once like this.
With the radio and heli powered up (not running) and the throttle trim centered, lower the collective stick (throttle), adjust the low end point in the radio so the mark on the barrel is just to the left of the 12 o'clock mark. Pull the throttle trim all the way down and make sure the carb fully closes (marks should line up). Go full collective and adjust the high end point so the marks at 9 o'clock line up and there is no binding. Now you are ready to start it with the collective all the way down and trim in the center. Once it's running you can adjust the low end point to get a good idle while you still leave the trim centered. Try to keep your end points close to 100%, if you are having to adjust it down to 50-60% to keep from binding, go in a hole on the servo arm.
RE: Rabid Raptor
ORIGINAL: navyav8tr
Thanks. I only tried to start it up once and that was enough for me. Good info guys, I appreciate it.
If you do not know what you are doing, PLEASE get local help. There are a number of ways to find local heli pilots that will be willing to help you. Do not be so prowd of yourself that you can't ask for help.
[link]http://pilotlocator.net/[/link]
[link]http://www.modelaircraft.org/clubsearch.aspx[/link]
I hope these links will keep you out of the hospital and out of the news. Less news makes a better hobby for the rest of us.
Rafael
RE: Rabid Raptor
Rafael,
I have been flying helis for 2 years and actually flying F/A-18s for the Navy for 12 years so believe me I appreciate your concern but I am not going to do something to embarass myself, degrade the hobby, or hurt someone or myself. I haven't flown my heli for about 6 months due to being deployed so I just got it out last night and it went "rabid" on me. Ended up the kids had messed with the throttle arm while I was gone. I was just looking for a quick answer or suggestions. Thanks anyway
RE: Rabid Raptor
ORIGINAL: navyav8tr
Rafael,
Rafael,
Good luck with your Raptor.
Rafael
IL
RE: Rabid Raptor
ORIGINAL: navyav8tr
Good Luck.
