Engine dies mid-air
Engine dies mid-air
I fly a R30 V1 with a TT36
The last 7-8 flights have all ended the unplesant way. The engine dies, and I find myself auto:ing down.
What's causing the engine to die?
It's not too rich or too lean, it's running fine up until it just stops.
I've checked (and replaced to be sure) all the fuel lines (and clunk lines).
I use a header tank.
Could it be a sudden loss of fuel pressure? (leaking exhaust gasket...?)
Any ideas?
Any ideas?
Engine dies mid-air
How long does it fly before the engine stops? Does it stop if you're only hovering? When you say it's not lean, did you check the temp., or only by judging from the smoke? Do you have a lot of fuel/oil on the inside of the frames/top of the fuel tank?
Engine dies mid-air
About 5-8 minutes.
I've been flying around most of the time, then stopping and hovering a bit. That's when the engine dies.
I haven't actually checked the temperature, and didn't notice if there was a lack of smoke, but rather that I had full power until the engine just quit.
Other times when the needle had been set too lean, there was a noticable loss of power, but no cut-out.
Yes, there is a lot of oil on the inside of the frame and on the tank, but that's probably because I don't clean it that often
Engine dies mid-air
Richen the engine out about 1/4 turn. If it helps, tune in leaner (about 5-600 rpm if you have a tach. Sounds like the engine won't pull fuel UP against gravity. Have you checked the engine full throttle, holding the plane vertical?? howell
Engine dies mid-air
I would try richening the engine as a test. Open the needle to the point where it's just about too rich to fly and see if the problem still occurs. If it doesn't, then gradually close the needle to the optimum setting and see at what point the problem re-occurs.
Of course I could be completely wrong in all this.
Engine dies mid-air
(It's not a plane, so using that technique for checking high-end rpm won't work)
Anyway, it seems to have helped to richen the engine... Did two flights yesterday, and the engine was running fine.
LOL, I'm not criticising your cleaning regieme! The reason I ask is that the TT36 is known to have a dodgy front bearing seal. A lot will start to leak significant amounts of raw fuel out through the bearing - having a lot of 'clean' looking oil on the top of the tank and inside the frames is an indication the bearing seal is gone. This might tie up with what Howell said, as the tank runs down you're gettting fuel starvation, compounded by the leaky bearing.
Ok, but I don't see how this could be the cause of the problem.
I mean, the engine was running just fine up until the point where it just quit. If the engine was too lean, it should have shown the usual symptoms; no or little smoke, really unwilling to rev up, loss of power, etc...
(I did change all the fuel lines as well, but couldn't see anything wrong with the old ones.)
Engine dies mid-air
Sounded lean to me too. Seems like you got it though. Richened it up and no more problem. Good deal. Have a blast with it now.
I got a temp gauge from Heliproz. haven't installed it yet but it is pretty cool and will give you good temp readings for setting the needle. Not something you need, but my boss really likes it and I think I will too. I have always set it by sound but will see how this works to see how close I was.
Re: I had the same problem
Originally posted by snowflyer
Check the three bolts on the engine backplate.
You ARE talking about the bolts acessible from below, right?
Engine dies mid-air
Hi
Check out curtis youngbloods web site re eng temps.
The smaller engines back plate temp should run hot getting cooler the bigger the engine, worked a treat for me, richened my OS50 until the back plate ran quite cool.
Also check your rotor rpm, most run far to high with the enginhe over reving and over heating.
good luck.
good luck.
Engine dies mid-air
I think I might have solved my engine problems ...for now anyway.
I just ordered a TT39PRO from Cyberheli. At $80 it's almost free!
