Raptor 50v2 Guide Pulley replacement
MN
Hi,
My last crash damaged my boom and pushed it into the main gear and broke a few teeth and also damaged the auto rotation pulley which I will replace. I noticed a small crack on the edge of one of the red guide pullys and was wondering if I could let it go. I'm changing the belt for good measure. It was quite mangled. I'm not a big 3D flyer but do occasionally beat it up. My other question is, to replace these pullys, do I have to totally disassemble the frame or is there a trick to it? Crap, this going to be my third parts order if I need to replace them. Wish I had done some research first. Still haven't figured out how to get out my mangled flybar from the metal head
Thx!
Thx!
RE: Raptor 50v2 Guide Pulley replacement
That pulley is spinning quite quickly, so I'd replace it if it is cracked. I'm sorry but I'm not aware of a shortcut on replacing it myself...maybe someone else has an idea? That is a very unusual part to have to replace - I've never replaced either of mine in 8 years (ok, I just jinxed myself , knock on wood!).
