rustolium fuel proofing
Hi my friends,I have used rustolium high performance gloss white on a wing seam.Does this need to be fuel proofed?I also have minwax polyurethane in a spray.I read as much as I can on the subject but still don't know the answer.I do know about the yellowing and it's not a problem.Sure would appreciate any help.Thanx.
RE: rustolium fuel proofing
I've found that the Rustoleum spray paints do need a clear coat. The problem is not the paint surface which doesn't get attacked, it is the ends of the spray. Even if I do all the holes for carb needle and what not in a cowl before painting it with Rustoleum, eventually the fuel soaks in around the edges of cutouts and gets under the paint and softens it and wrinkles it up around the edges. The ones that I've clear coated with Minwax Helmsman don't suffer the problem. I use a club fuel that is 15%.
This problem might be stopped if painting both the inside and outside of a cowl.
On the other hand, I hand paint a firewall often with Rustoleum enamel (non aerosol) and it holds up without issue.
I have used the Rustoluem with no issues... Just make sure that you let it gas off ( cure) a few days before flying. The have used it up to 20% nitro.
I had problems with grey many years back. But if let cure for about a week before putting fuel to it, solved the problem. I used it on the inside cabin area of a Decathalon. About a day later had a fuel tank leak when I filled up to test the engine. The grey wiped right off. Cleaned up and repainted with no problems on the inside. I used that grey later on the bottom of a P-40 with no problems around the exhaust area. Good point about the through holes. I never used it on firewalls, just thinned epoxy for fuel proofing.
Edwin
Edwin
I agree.. I use thined expoy on firewalls also... I have also used the rustoluem APPLIANCE EPOXY SPRAY. It great for firewalls and cowls also.
the down side is the limited color choices.
Check out website http://www.rustoleum.com/CBGProduct.asp?pid=101
My Feedback: (20)
GA
Hey AA5BY, do you just use the regular Rustoleum in a quart or pint can like this? http://www.rustoleum.com/CBGProduct.asp?pid=150 Do you still have to stick to just the gloss? If Rustoleum hand brushed works, can I not just go to HD and buy something like Behr latex enamel and that work ok? With the Minwax Helsman have you had a problem with it yellowing over time?
