If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 2 of 2
  1. #1
    Join Date
    Jun 2012
    Baltimore , MD
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    OS Max 91 fx rebuild help (Disassembly Pics Wanted)!!
    As the title states im looking for a few pictures of the process. Ive torn the engine down to just the crank, piston, and sleeve and am new to R/C engines. How do Igo about getting out the piston and rod?Do Ihave to push out the sleeve then pop off the connecting rod, then the crank?Either way I have another 91 to use if for some god awful reason Ido something wrong which im confident Iwont..... With a little guidance of course!
    Thanks in advance and sorry mods if this is in the wrong section.
    Adam
  2. #2
    Join Date
    Nov 2002
    huron s.d.
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: OS Max 91 fx rebuild help (Disassembly Pics Wanted)!!
    You need to remove the sleeve & then the rod will come off the crank. Warm it up good with a heat gun & push it out from the bottom w/a hunk of wood or dowel. Max
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
