If this is your first visit, please click the Sign Up now button to begin the process of creating your account so you can begin posting on our forums! The Sign Up process will only take up about a minute of two of your time.
Results 1 to 5 of 5
  1. #1
    Join Date
    Sep 2005
    Fond du Lac, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Remove paint from tires?
    Anyone know of a good way to remove dried spray paint overspray from tires without harming the rubber?
    Roy
  2. #2
    KitBuilder's Avatar
    Join Date
    Feb 2007
    Palm Harbor, FL
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    RE: Remove paint from tires?
    If its specs.. you can take a shish-ka-bob spear tip (bamboo ones) and flick it off either lifting an edge or picking at the paint. The bamboo won't hurt the tire unless your to agreesive.
    Mike -
    I was born a pilot... 100 years to late.
  3. #3
    Join Date
    Sep 2005
    Fond du Lac, WI
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Thanks for the advice, but it's a lot more than specks. In some places it's almost completely covered. I purchased the plane with this problem and I'd like to clean it up. I can remove the tires to work on them, but I just want to know what to do. Thanks in advance.
    Roy
  4. #4
    catracer343's Avatar
    Join Date
    Apr 2006
    Hillsborough, NH
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Grab a can of acetone from your local parts store or hardware store...it will wipe it right off! Most fingernail polish removers are acetone, but about 3 times the price...I guess they know most women don't hang out where guys do!
    Stop thinking about it and just build it! AMA #418127
  5. #5
    Join Date
    Jun 2005
    Houston, TX
    Gallery
    My Gallery
    Models
    My Models
    Ratings
    My Feedback
    Overspray won't hurt the functionality, them tires will work fine. If you want it cleaned for cosmetic purposes, a solvent may work but which solvent will depend on the type of paint and it might attack the rubber. As they say, test in an inconspiciuous area first. Start with acetone and ramp it up from there until it starts damaging the tire. Another option would be to scuff sand, that should clean it off. If all else fails, new wheels aren't expensive.
    Dave
Posting Permissions
  • You may not post new threads
  • You may not post replies
  • You may not post attachments
  • You may not edit your posts
RCU Reviews
SEO by vBSEO 3.6.1 ©2011, Crawlability, Inc.
