Homemade sealing iron socks
Reply
Old 10-20-2018, 08:26 AM
ETpilot
ETpilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well I made 4 socks. I marked my pattern with a series of pen marks, left side. Then sewed along the marks, right side. Cut off the excess and turned it inside out. They came out pretty good. I do have to add 3/4 to the length so they are easier to tie-wrap to iron.
The Walmart material is about the same in thickness. The thread count is just a bit less than original. But it should work good. Ill find out soon. It is raining in Texas so good day to be covering. The hardest part of this job was learning how to use the sewing machine again. Been a while. Had to read the How To Manual.
ETpilot is offline
Old 03-02-2019, 03:09 PM
ETpilot
ETpilot's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I finally got to put my sock to good use. It worked pretty good. On the next batch Ill make them a little bit narrower and a bit longer. I have enough material left for a few airplanes.
ETpilot is offline
