Reload this Page >
Paint to use on Solartex Fabric Covering ?
Reply
Old 06-18-2016, 05:35 AM
crankpin
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
All painted striping needs the best tape, 3M or Scotch masking tape, IMO only. After applying, dust the edges with clear, let dry for some time. Then start to add the color, dust first, then the heavier coats, not like finishing final coats. Pull the masking tape off, directly over itself. Included here, pictures of past projects, glass fuselage, foam cores, balsa covered, glassed, with finishing resin. Taping on these projects, is a lot of work, on and off, mask, cover, etc. See the project in your mind, then go to it. Final on these projects, wet sand, then clear it all.
Vince
ID:	2168467   Click image for larger version
ID:	2168469   Click image for larger version
ID:	2168470   Click image for larger version
ID:	2168471   Click image for larger version
ID:	2168472   Click image for larger version
ID:	2168473   Click image for larger version
ID:	2168474   Click image for larger version
ID:	2168476   Click image for larger version
ID:	2168477   Click image for larger version
ID:	2168478   Click image for larger version
ID:	2168479   Click image for larger version
ID:	2168480   Click image for larger version
crankpin is offline
Old 09-10-2016, 01:34 PM
jollyroger
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've got a BUSA Bristol M-1 covered with what I believe to be 21st Century fabric, not sure, it could also be Solartex.....don't say nuthin' I bought from An estate so I don't know which one, anyway, since it needs to be painted with some sort of olive drab color krylon O.D. may be the best bet, ah but I do have access to a couple cans of O.D. from a well known but now OOB manufacturer.
Testing for performance values takes time so I will just go ahead and paint the durned plane.
jollyroger is offline
Old 09-10-2016, 01:44 PM
crankpin
My Feedback: (12)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
JollyRoger. Go to: www.balsausa.com They can fix you up, give them a call.
Vince
crankpin is offline
Old 09-19-2016, 12:23 PM
kenh3497
kenh3497's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Don't use masking tape. Use a product like the 3M fine line tape. I have used electrical tape in a pinch , but it is a far cry from the 3M stuff
Ken
EDIT: Use the fine line tape for the outline of your color change then you can use masking tape over the fine line to completely mask off the non painted area.
kenh3497 is offline
Old 09-28-2016, 09:09 AM
Gtarling
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Tamiya masking tape - the best on tex fabrics!
Gtarling is offline
Old 09-28-2016, 01:37 PM
  #31
TomCrump
TomCrump's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I prefer the profession grade tape, used by automotive painters. 3 M fine line tape has never let me down.
This Spacewalker is covered in Natural Solartex and then painted. The masking tape used was the 3 M product.
TomCrump is offline
Old 11-09-2016, 04:17 AM
  #32
OldScaleGuy
OldScaleGuy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I agree, 3M fine line is best. I am using Klass Kote paints for the first time and really liking this material. The control surfaces of the Hellcat i am painting are Solartex covered with no primer and coming out as good as one could ask for. It is a higher cost paint than latex but the advantages of Klass Kote are worth every extra penny. Just my .02 cents worth.
OldScaleGuy is offline
Old 03-13-2017, 08:56 PM
  #33
dutchy50
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hi Granpooba
I have painted solartex, if you buy the auto touch up paints from Supacheap auto in spray cans they will go on with no primer needed. I have done some samples by ironing some Solartex on to a flat board, taping the areas I want to spray, then sprayed the area, left overnight to dry. I then poured 10% nitro fuel onto the solartex and paintwork. Showed no signs of paint coming off!!
Dutchy50
dutchy50 is offline
Old 02-06-2018, 10:02 PM
  #34
cymaz
cymaz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Solarfilm is now going to close. It will cease trading on 12 February 2018...a real loss to the modelling world.
cymaz is offline
Old 02-07-2018, 03:56 AM
  #35
OldScaleGuy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Does Solarfilm have any thing to do with Solartex?
Old 02-07-2018, 09:22 AM
  #36
cymaz
cymaz's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Solarfilm makes solartex and solarlac......or did
http://www.modelflying.co.uk/forums/...?th=133639&p=1
This will explain some of it and the letter from the company is on the thread
cymaz is offline
Old 02-07-2018, 09:35 AM
  #37
OldScaleGuy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This is bad news or should i say more bad news for the hobby industry.
Old 02-07-2018, 11:17 PM
  #38
dutchy50
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Solatex
Looks like its back to the Silk and dope method!!!
dutchy50
dutchy50 is offline
Old 02-09-2018, 07:16 AM
  #39
OldScaleGuy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Balsa USA is indicating that they are hard at work trying to find a replacement. We shall see what they come up with, hopefully in the near future.
Old 02-10-2018, 04:42 AM
  #40
TomCrump
TomCrump's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
This may be an option. https://www.oracover.de/fabric/1
TomCrump is offline
Old 06-17-2018, 06:14 AM
  #41
sailr
My Feedback: (25)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Water based paint
Originally Posted by TomCrump View Post
Tap water is used whem the manufacturer makes latex paint. Why would anything else be required to thin it ?
Use windshield washer fluid to thin latex. It will let it flow out without runs. Just water doesn't work that well. You can also add a bit of floetrol to the latex.
You do NOT have to prime Solartex. I always use latex on my warbirds because it gives a reasonable flat. My planes are all gasoline powered and no need for clear coat as the exhaust residue will not attack latex.
sailr is offline
Old 06-17-2018, 06:15 AM
  #42
sailr
My Feedback: (25)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The worst news in model building in many years is that solartex is no longer being made. DAMN. You can say what you want about Stits Lite, Coverite, etc. but they do not measure up to solartex in any way. Coverite is also much more expensive.
Now if some enterprising chinese factory, (or anyone else for that matter), would start making a solartex equivalent I'd beat a path to their door.
sailr is offline
Old 06-17-2018, 06:58 AM
  #43
TomCrump
TomCrump's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Windshield washer fluid contain products that are not in latex paint formulas. as a 30 year + latex paint manufacturer, I hesitate to add products not included in the original formula.
TomCrump is offline
Old 06-17-2018, 07:33 AM
  #44
sailr
My Feedback: (25)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I don't care about the technical ingredients in latex paint. I'm just saying that with 50 years experience building models and painting with latex that WINDSHIELD WASHER FLUID WORKS.
sailr is offline
Old 08-11-2018, 12:14 PM
  #45
ExtraCGScott
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would love to see a great classic company like Balsa USA or Sig buy and secure the Monokote line from Horizon Hobbies...
ExtraCGScott is offline
Old 09-08-2018, 06:45 PM
  #46
r ward
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
polyester dress lining material from a fabric shop will work just fine. it will even shrink a bit to tighten up like monocote with a monocote iron. just be sure to use a sock on the iron.. I apply it with brush grade lacquer like applying silk or silkspan.
r ward is offline
