Paint to use on Solartex Fabric Covering ?
My Feedback: (15)
All painted striping needs the best tape, 3M or Scotch masking tape, IMO only. After applying, dust the edges with clear, let dry for some time. Then start to add the color, dust first, then the heavier coats, not like finishing final coats. Pull the masking tape off, directly over itself. Included here, pictures of past projects, glass fuselage, foam cores, balsa covered, glassed, with finishing resin. Taping on these projects, is a lot of work, on and off, mask, cover, etc. See the project in your mind, then go to it. Final on these projects, wet sand, then clear it all.
Vince
Vince
I've got a BUSA Bristol M-1 covered with what I believe to be 21st Century fabric, not sure, it could also be Solartex.....don't say nuthin' I bought from An estate so I don't know which one, anyway, since it needs to be painted with some sort of olive drab color krylon O.D. may be the best bet, ah but I do have access to a couple cans of O.D. from a well known but now OOB manufacturer.
Testing for performance values takes time so I will just go ahead and paint the durned plane.
Don't use masking tape. Use a product like the 3M fine line tape. I have used electrical tape in a pinch , but it is a far cry from the 3M stuff
Ken
EDIT: Use the fine line tape for the outline of your color change then you can use masking tape over the fine line to completely mask off the non painted area.
Ken
#31
#32
I agree, 3M fine line is best. I am using Klass Kote paints for the first time and really liking this material. The control surfaces of the Hellcat i am painting are Solartex covered with no primer and coming out as good as one could ask for. It is a higher cost paint than latex but the advantages of Klass Kote are worth every extra penny. Just my .02 cents worth.
NerdSteve01 (11-19-2021)
#33
Hi Granpooba
I have painted solartex, if you buy the auto touch up paints from Supacheap auto in spray cans they will go on with no primer needed. I have done some samples by ironing some Solartex on to a flat board, taping the areas I want to spray, then sprayed the area, left overnight to dry. I then poured 10% nitro fuel onto the solartex and paintwork. Showed no signs of paint coming off!!
Dutchy50
Dutchy50
#36
Solarfilm makes solartex and solarlac......or did
http://www.modelflying.co.uk/forums/...?th=133639&p=1
This will explain some of it and the letter from the company is on the thread
#40
#41
My Feedback: (25)
Water based paint
You do NOT have to prime Solartex. I always use latex on my warbirds because it gives a reasonable flat. My planes are all gasoline powered and no need for clear coat as the exhaust residue will not attack latex.
#42
My Feedback: (25)
The worst news in model building in many years is that solartex is no longer being made. DAMN. You can say what you want about Stits Lite, Coverite, etc. but they do not measure up to solartex in any way. Coverite is also much more expensive.
Now if some enterprising chinese factory, (or anyone else for that matter), would start making a solartex equivalent I'd beat a path to their door.
#43
Use windshield washer fluid to thin latex. It will let it flow out without runs. Just water doesn't work that well. You can also add a bit of floetrol to the latex.
ThunderBoat42 (02-24-2021)
#45
#46
polyester dress lining material from a fabric shop will work just fine. it will even shrink a bit to tighten up like monocote with a monocote iron. just be sure to use a sock on the iron.. I apply it with brush grade lacquer like applying silk or silkspan.
