filets on plug in wing
Reply
Old 07-29-2017, 09:38 PM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default filets on plug in wing
Is it possible to make fillets on plug-in wings ?
vasek is offline
Old 07-30-2017, 08:57 AM
RBACONS
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The wing would have to have a constant rib thickness (i.e., no taper toward the wing tip), and the wing tube would have to be parallel to the top surface of the wing. Otherwise, the root rib would not be able to slip under the outer edge of the fillet. Alternatively, I suppose one could build the filet on the wing itself rather than the fuselage but one would have to be creative to make the fuse/fillet seam look OK when looking down on the plane.
RBACONS is offline
Old 07-30-2017, 10:37 AM
Hydro Junkie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
My thought would be to build it up on the wing. Easy way would be to put wax paper on the sides of the fuse and build up the fillets up to what you want using slow cure epoxy mixed with major amounts of micro-balloons. When the epoxy is cured, touch up as needed with a fine grit sandpaper and paint. Obviously, the wax paper is just a release agent so if you know of something you'd rather use, us it
Hydro Junkie is online now
Old 08-04-2017, 02:52 PM
ibuild
ibuild's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anything is possible, just need to find out exactly how...
ibuild is offline
Old 08-04-2017, 02:53 PM
ibuild
ibuild's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Anything is possible, just need to find out exactly how it's best to do it...
ibuild is offline
Old 08-05-2017, 04:09 AM
TomCrump
TomCrump's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Hydro has the right idea, but many use Monokote in lieu of the waxed paper.
The covering is applied, and the waxed. After the fillet resin cures, the covering is removed.
I place the fillet on the fuselage, and cover the wing, in the fillet area.
TomCrump is offline
Old 08-06-2017, 08:14 PM
Hydro Junkie
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's why I said, if you have something you'd rather use.....................................
Glad to see someone actually likes something I suggested. Usually, it's more of a "say what????????????" reaction that I get
Old 09-04-2018, 04:32 AM
vasek
vasek's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I found the answer to my question. Posting info for others.
This will ad a little to the overall wingspan unless you cut the piece directly off the wing (talking about an ARF wing mod)
I will ad the extension to the fuse and leave the wing alone. It' easier that way if the plug in tubes are already installed (ARF mod)
vasek is offline
Old 09-08-2018, 06:13 AM
jester_s1
Moderator
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
That's a pretty slick way of doing it. Alternately, you can start the fillet with the 1/32 plywood on the fuselage, then plug the wing in and put a layer of balsa or filler up to it that you feather out for a few inches.
jester_s1 is offline
Old 09-09-2018, 07:17 AM
r ward
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I would think, as shown, the filet should be on the fuse. it's easier to build the filet and better to keep the filet on good shape.
r ward is offline
