P-51 Foam Wing: Are Spars Necessary?
My Feedback: (9)
I am about to start sheeting the foam wing cores for my 69" ws P-51. I am wondering if the wings need spars added for strength? I was going to add to each panel, (2) 1/4 x 3/8 spruce spars, top and bottom, from the root to the tip, as you would do on the plans for a built-up wing? Is this overkill?
Thanx, Mark
Thanx, Mark
Just my opinion, without engineering calculations, but I think spars would not be necessary on a sheeted foam wing. Over the years, there have been lots of such wings flying just fine. For example: SIG Kougar and King Kobras have sheeting only, with no spars. Adding spars would add complexity and weight, with just a little gain in strength that isn't needed.
You need to add servo rails for ailerons/flaps and anything like wing tube sockets if applicable. Here is a buddy of mine holding my wings.
Bob
After sheeting
Before sheeting
Bob
After sheeting
Before sheeting
