Let's see your work shop!
#801
MN
RE: Let's see your work shop!
Finally settled into my new shop, still organizing, but ready to start making balsa dust. Pics to come, but I know right now, I'm going to need a lot more outlets! Having a bathroom in the shop makes for a great place to store planes!
#804
QC, CANADA
I have a few before pictures (my dining room table), and need thoughs for after pictures. Moving to a second bedroom (10 x 10), and want work bench (table), shelfs, charging station. I have 2 planes and 6 helis (CP Pro 2, 450, 500).
Considering folding table (6 foot), wall mounted shelves, and perhaps pegboard (may go for storage boxes instead). I have a tool tray which I like very much.
#805
MI
well my shop has gotten face-lift #8 here is where i am at now..
i installed a gas heater for our cold winters and have taken over the entire garage..
so far so good really enjoying not having to take the planes up and down the stairs
#806
QC, CANADA
ORIGINAL: gi1mo2
#813
TX
For all of you that have workshops in your basements or house, how do you keep the fumes out??? I will be building mine in my spare bedroom, but I do not want to be getting high from the glue fumes. How do you prevent this. I can open the window, but is that enough??
#814
NC
No the fumes are heavier than air. like gas vapors in a boat's engine compartment. If you want to use the window you need a small fan on the floor to disturb the air and one of those two fan unites in the window to suck the fumes out.
We had a club member almost die in his basement. He was sitting at his bench doping a plane and got light headed. He tried to stand up but fell down. He crawled up the stairs from the basement and passed out at the door. Luckily he had crawled out of the fumes before he had passed out.
I used the two fan system for years in two bedroom apartments with no problems. I would suggest that you try and time your doping or painting in the fall and spring. sucking 25 or 100 degree air into your home tends to run up the power bill. Also the humidity levels are better for the paint.
This schedule worked for me here in NC
Dec Jan Feb - Frame up planes
March April May - Cover and paint framed up planes
Jun July Aug - Fly and stock up the shop for the winter.
Sep Oct Nov- Cover and paint
#815
NC
I moved to a new place and up graded from 200 sq f work shop to a 700 sq f one. Still working on getting it set up. Almost finished with the 4'x8' magnetic torsion box work bench. Still have to finish construction on the balsa cabinet/ helicopter work bench that you see the Cloud Dancer resting on. Got the new shelving installed last week. What was nice was that the guy that build this house originally was a cabinet maker so the workshop has tons of lighting installed and electrical outlets every two feet around all four walls. Plus some 220 v connections.
#819
NC
Wow all these really neat man caves, heres my little side of a work shop in the garage, oh yea, the wife still insist that a vehicle is allowed in. But it suits not having to use the dinning room table. Does get cold in the winter and hot in the summer. But soon I will have all that worked out, I plan to sheetrock and add more lighting plus heat/air soon and the car will go to the driveway!!!!!!!
#823
You guys may remember a post I had on this thread several years ago wher I remodeled my shop. Well I finally decided to tear it down and build a new shop. This shop is a little more friendly to my Model Airplane addiction.
#825
I too posted my workshop here a long time ago. While I haven't remodeled, I do have a new addition to the shop. I added a CNC machine at the begining of June. I haven't cut any aircraft parts yet, but have cut a couple of signs and a sand paper organizer. I'm already learning the areas where I want to make improvements to the machine. There is some flex that is noticable when working with thicker and harder stock that I want to resolve. It wll do for cutting balsa and light ply and I also want to eventually be able to cut foam for making plugs and molds and wood forms for vacuum forming.
Scott
Scott
