Removing fuel from balsa
A few weeks ago when packing up my cloud dancer after a days flying I found that the fuel tank had been leaking. How do I get the fuel out the balsa? The area that is soaked is not very accessable. I have searched and found that most people suggest using a spot remover called KR2 or something. Unfortunatly I'm in Australia and can not find this remover anywhere.
What else could I use? Would talcum powder work?
RE: Removing fuel from balsa
I too have filled up a few engine compartments with fuel !! []
I use CAT LITTER ! Just fill up the affected area and set it aside for a day or two and it will be dry as a bone ! It is very absorbent as you can imagine. You do have cats in Aussie Land ? LOL !
Another method is to use the oil absorbent stuff mechanics use to suck up the oil spills under the vehicles they've worked on. I think it's called "Ever Dry" over here. Comes in bags and is relatively cheap. Apply in the same way, Just pour it in and shake it out !
Hope this helps....
Hope this helps....
If yu can find 100% denatured acohol and put it in a spray bottle. Flush it out and let it dry. Do this a few times and the oil will be gone. Do this OUTSIDE or you may turn your plane it to a very fast burning candle.
Dru.
Dru.
Talcum Powder will work... corn starch is better...
If it's really bad...mix corn starch with a little alcohol and make a paste..rub it on the area and let it dry the flake off the dried corn starch.
I have used the K2R remover in the past and it was very good, as the fuel was soaked deeply into the wood. I am not able to find it now and would like to know if you think the corn starch and alcohol slurry will be able to draw out very well.
BTW So that others can learn from my mistake.
Make sure that if you store a YS powered plane on its nose, that you depressurize the tank before you stand it up on end. I now have about 8-10oz of fuel in the nose of a PT-19, oh well.
My Feedback: (61)
I find that lighting a match and touching it to the wood does just the best job of eliminating the fuel. Works a lot faster than starch or litter.
Nyuk Nyuk..
DP
Nyuk Nyuk..
DP
AR
ORIGINAL: Terror Dactyl
I have used the alcohol-corn starch slurry with reasonable success, almost as good as K2R just more difficult to apply. Improved results were obtained by 'warming' the oil soaked areas with a heat gun after brushing on the slurry.
AR
ORIGINAL: desertpig
Nyuk Nyuk..
DP
Nyuk Nyuk..
DP
hi
treating the wood with balsarite will do wonders in restoring strength to the wood. I use this as fuel proofing area around engine and fuel tank.
happy flying
joe
happy flying
joe
This might also be useful/interesting. It lists K2R ingredients (among others):
[link=http://householdproducts.nlm.nih.gov/cgi-bin/household/brands?tbl=brands&id=19005003]Household Products Database[/link]
