Cutting the Canopy
RE: Cutting the Canopy
Curved scissors work much better. Here is an example
http://www2.towerhobbies.com/cgi-bin...&I=LXL464&P=ML
The car guys use them as well and they may be called body scissors at the LHS.
I actually have those scissors and have used them quite a bit on different plastics that need trimming. My question is I have used them to trim a canopy but I still get some rough spots where the canopy has been trimmed. What are you guys using to smooth out the rough spots but not damage the canopy itself.
Patrick.
Patrick.
Patrick:
I just use a sanding block along the canopy edge. Just stuff a towel or rag inside the canopy so it doesn't squash while you sand.
Brian
Brian
For the final fit, I tape a piece of sand paper to the airplane and use it as a stationary sanding block to smooth the edges of the canopy to an exact fit. Hold the canopy carefully so that you don't distort it and get an unanticipated edge shape. I have always thought this was the way everyone did it. [:-]
Jim
Jim
