16X6 Prop Reaming... Need help!
I have a standard size prop reamer that goes to 3/8 which is not big enough for my Saito 150 shaft. How do you get the right size for the bigger props? I checked with Tower and all the reamers they sell are only up to 3/8 too.
Thanks!
KZig
Thanks!
KZig
GA
RE: 16X6 Prop Reaming... Need help!
Your local hardware store should have a tapered reamer which can be made to work. Just ream from both sides and get the minimum diameter to where it just fits.
Jim
Jim
My Feedback: (24)
ORIGINAL: KZig
Here is one that can ream up to 10mm: [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXEGH6&P=ML]Great Planes Precision Prop Reamer Metric[/link]
Here is another: [link=http://www2.towerhobbies.com/cgi-bin/wti0001p?&I=LXNL18&P=7]Fox Prop Reamer Metric 10 & 12mm[/link]
My Feedback: (24)
ORIGINAL: hookedonrc
I think you will find that 10mm is right at 3/8" and that KZig is asking for reamers larger than that.
My Feedback: (9)
Seems as if you would end up with an hour glass shaped hole if you used a tapered reamer. A prop reamer or prop drill bit cuts the hole one size all the way through. Maybe it doesn't matter.
