Drilling wheel hubs out?
Reply
Old 12-24-2005, 03:58 PM
wsmalley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Drilling wheel hubs out?
Got a new set of 5 1/2" Dubro wheels that go on 1/4" axles. Drilled them to 1/4" but they're too tight. Whats the ideal next size drill up to get them right? I don't want any excess 'slop'. Thanks, Bill
wsmalley is offline
Old 12-24-2005, 04:57 PM
bkdavy
bkdavy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Drilling wheel hubs out?
Roll up a piece of sandpaper, put it through the hole, and rotate the wheel around the paper. You'll take off just enough to fit the axle.
Brad
bkdavy is offline
Old 12-24-2005, 07:49 PM
the-plumber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
In order of increasing size,
6.5mm, F, G, and 17/64".
You _might_ have the last one.
Otherwise, sand as advised above.
the-plumber is offline
Old 12-25-2005, 08:57 AM
TLH101
TLH101's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Try using a prop ream in the correct size. I have found that when drilling wheels, the hole always seems to shrink just a touch after drilling. I think maybe heat build up causes it. Just drill it like you normally would, then run your prop ream through, and you will have a nice fit that does not bind or wobble.
TLH101 is offline
Old 12-25-2005, 12:20 PM
da Rock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
If you have a solid mount for your drill, move the wheel up and down the turning bit a couple of passes.
da Rock is offline
Old 12-25-2005, 12:30 PM
da Rock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You know, I bet a bunch of you think this is overkill but.........
Years ago I lived in a big town. There were a couple of industrial supply houses. They looked to me like big NAPA stores only they sold lathes, mills, etc, and all manner of bits and machine shop supplies etc. I was trying to make my own pistons at the time and needed accurate holes. Reamers are the answer, not drills. Those supply houses sold every size imaginable. I decided to buy a couple in sizes that would help those simple tasks, like getting accurate wheel/axle holes.
Since I've never been real happy with running a drill bit into those plastic wheels, it's almost impossible to get an accurate hole, I've been happy as a fly on a pig's lips to sit and turn that "expensive" reamer by hand.
I've not looked, but I bet there is at least one internet site for reamers, real "industrial strength" ones. Mine weren't much more expensive than the drill bits you see on the wall at Home Depot or Lowes Home Improvement.
da Rock is offline
Old 12-25-2005, 03:09 PM
wsmalley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Your right about the reamers. Anything, I believe, properly machined with a 'round' hole is reamed. I will check my prop reamer-hadn't thought about that! I did fiddle last nite on one with the sandpaper, and it is working-but man, is that tedious. Personally, I'm one who normally needs instant gratification! Guess I would need the 'F' reamer, I have a few letter drills in the box, wish I had a whole set.
wsmalley is offline
Old 12-26-2005, 09:53 AM
SST
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
The reamers Darock is talking about are sold as oversize dimentional reamers. You'll find the 1/4" range marked as .248, .249, .2495, .250 .2505 .251, .252 etc. You can find them for fractional or metric sizes. Try www.enco.com for individual pieces or whole sets.
SST is offline
Old 12-26-2005, 01:02 PM
the-plumber
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Quote:
ORIGINAL: TLH101
Most drills aren't really sharp enough to cut the plastic precisely, and even though material is indeed removed during drilling, the plastic also deforms a bit to accomodate the drill bit, resulting in a hole that is smaller than would have been made in metal.
Try drilling and tapping UHMW (Ultra High Molecular Weight) plastic some time. No matter how many times you run a tap through the threads, the threads will be very tight when trying to run in a machine screw. BTDT. Next time I need tapped holes in UHMW I'll use threaded inserts.
Old 12-26-2005, 01:40 PM
wsmalley
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Well, thanks for the tips guys. Fred: you're right about drilling that plastic! I wound up using the prop reamer and rolled up sandpaper and got a nice smooth fit. The sandpaper method took a loooong time, and quite boring, but, it was do something, or watch 'Lifetime' movies with the wife. Those are some of the most boring movies ever made! They could be used for interrogating prisoners: "Talk or you watch 3 Lifetime movies in a row!"
wsmalley is offline
Old 12-27-2005, 03:16 PM
JPMacG
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I finally broke down and bought a set of lettered and numbered drills to add to my fractional inch drills. The extra sizes have been handy many times. They are not usually found in comsumer hardware stores - you need to get them mailorder or from an industrial supply place. Watch out for low-quality imports.
JPMacG is offline
Old 12-27-2005, 06:10 PM
pcjohnson_ohio
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I've drilled an oversized hole and used heat shrink tubing on the axle
Worked well
Pete
pcjohnson_ohio is offline
Old 12-27-2005, 08:32 PM
Gollywock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Or drill it oversize and shim it with a brass tube from K&S -Jim
Gollywock is offline
Old 12-28-2005, 11:10 AM
MinnFlyer
MinnFlyer's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
What I will often do is to glue a piece of sandpaper to a dowel - in this case, if the hole is 1/4" you could use a 1/8" dowel (or maybe a 3/16" dowel with a shorter piece of sandpaper)
Glue one edge of the sandpaper to the dowel, then wrap it around the dowel. Put the dowel in a drill, insert it into the hole and the centrifugal force will push the sandpaper against the hole.
MinnFlyer is offline
Old 12-28-2005, 12:11 PM
CCRC1
CCRC1's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
wsmalley,
I have a suggestion you may want to look at. I am not fond of the plastic wheel running on a steel axle and bearing the load of the airplane. Every one that I have ever had like that ended up wearing prematurely. I would rather drill the wheel to accept a nylon or bronze bushing. I found some nice smaller size nylon flanged bushings from SIG, and for the larger sizes, hit your LHS in the RC car section. Most of the time bushings are replaced in RC cars with bearings so they are fairly easy to get. Finding some with an ID. of 1/4" shouldn't be to hard. You may even get lucky and find some flanged bearings with that ID.
CCRC1 is offline
Old 12-28-2005, 06:31 PM
da Rock
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Brass bushings?
The K&S tubing is sized so that each tube size fits rather well into the next size larger. It's quite easy to use for a fixed bearing on the axle, or fixed bearing in the wheel, or both. And since drill sizes match up as well, it's easy to create an appropriate sized hole in the wheels.
The only very slight problem I ever ran into using that tubing as wheel bearings was on a CL rat racer that lived far longer than those suckers usually do. The high nitro fuel and the way it's slopped around a rat racer must have kept the wheel (only had one) wet every time we flew it. And brass is not a good metal to use around fuel. (Which is why I'm constantly amazed that most fuel tanks still are sold with brass clunks and tubing.) And one day I noticed the tire was showing grey-green stains. It still turned great, but it was obvious the brass was reacting to the fuel baths. (Have you ever opened up a really old fuel tank and looked at the brass inside?)
da Rock is offline
Old 10-02-2013, 09:22 AM
GoNavy
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I realize this thread is very old, but the advice was spot on. I used the prop reamer and got 1/4 inch.
I had used a 6.5mm drill bit, that is .2559, but the hole was still so tight you could not push the axle in.
Thanks to all.
GoNavy is offline
Old 10-03-2013, 08:31 PM
Leroy Gardner
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
An F letter bit will do it, it's used to drill holes for 1/4" rivets so you can get the rivet in them and buck um. Works great on hubs as well.
Leroy
Leroy Gardner is offline
Old 10-19-2013, 01:01 AM
bikerbc
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
It also helps to put your wheels in the freezer for a little while first .. then I go up a size in bits .. I have a set of number bits and I use them .. Its not a big deal if there is a little bit of play as long as its not too much .. It will allow room for a bit off grease or oil .
bikerbc is offline
Old 10-21-2013, 07:12 AM
dadragon
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
+ 1 bk & minnflyer
dadragon is offline
Old 07-28-2014, 09:32 AM
Marty79
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
You might try a 17/64 drill in a drill press turning as slowly as possible to prevent heat building up
Marty79 is offline
Old 07-29-2014, 04:01 AM
CafeenMan
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I drill for a brass tube that fits the axle. Then I can press the tube in place and the clearance is perfect.
Generally when you need to drill holes that become bearing surfaces you're going to need number and letter drills. Fractional drills will never be the exact right size.
CafeenMan is offline
Old 07-29-2014, 04:31 AM
sensei
sensei's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
F drill = close fit for a 1/4 dia axle.
H drill = free fit for a 1/4" dia. axle.
Bob
sensei is offline
Old 08-03-2014, 06:48 AM
Villa
Villa's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Sometimes, if the hole just needs to be a little larger, I will use a slightly larger drill, and force it thru the hole, but in reverse direction. Sometimes this works OK.
Villa is offline
Reply
Display Modes
