Reusable Epoxy tool
NJ
Reusable Epoxy tool
I was just wondering if any body has found or developed something that can apply EPOXY and then be scraped cleaned or dunked in something to keep it from bonding on to the applicator.
RE: Reusable Epoxy tool
A nylon prop, like a master airscrew, would probably work. Clean with alcohol or acetone while the epoxy is wet. Or let it cure and then flex the blade to pop it off.
MS
I like to use the little food sample cups and spoons that Sam's Club uses. I ask if I can go thru the trash cans and get a dozen or so, then take them home with me and clean them and re-use them. The cups will hold more than you usually will want to mix at one time, and the little spoons make neat applicators to dip and spread the epoxy. Afetr you're through, throw them away (again).
i use a tool a painter uses or artist type who mixes differant colors on a eisel it has a wood handle and is kind of shaped like a bent butter knife when done wipe with a rag or paper towel with rubing alcahol or wait till it sets and use a knife and it will scrap right off with little effort its stainless and flexs and is perfect for mixing and applying epoxy
NJ
Thanks this sounds like the tool I need. I was using $1.99 paint brushes but I fiqure this can get expensive. So I will look for the name of the tool and invest in one .
My Feedback: (9)
I bought a box of wooden coffee stirrers 10 years ago. I can just begin to see the bottomof the box. You can always grab a few extra when you buy coffee at Caribou or maybe Starbucks.
Walt
Walt
My Feedback: (9)
TX
Since your question was about a tool to apply epoxy I'll show you a picture of what I've been using for the last twenty five or so years.
It's a small mixing spatula found at most any artists or craft shop. The handle is wood and the blade is steel. You can use it to mix your epoxy and apply it as well. It will clean up with a swipe of an alcohol dampended paper towel and if you get too busy to clean it immediately use it you can easily shave the cured epoxy off with a single edge razor blade. I have one that is at least twenty years old and it's still going strong. The price is only a couple of bucks.
ORIGINAL: RC-FIEND
http://www2.towerhobbies.com/cgi-bin/WTI0001P?&I=LXK362
I use them once and toss them
NJ
Thanks all but Tashley's and Tbones' ideas is what I am looking for at the moment , I do like the wooden coffee stirrers idea, but i already can see how I would end up using them for other things which then becomes a waste.
So I will pick up a spatula ASAP and will give it a shot.
The tool is called a pallet knife. It is available at arts and craft stores, department stores that carry art supplies, and some building supply houses. It is hard and flexible and is excellent for mixing and applying epoxy. I have used one for many years.
My Feedback: (9)
TX
Acid brushes are another great tool to have and they are so inexpensive you can afford to use them to apply epoxy, such as brushing a coat on the firewall, and then toss them. I prefere to "warm" the epoxy a little before brushing it on the firewall as opposed to thinning with alcohol which can sometimes cause the epoxy to not cure properly. Just don't overdo the heat or it will kick before you have it brushed on completely.
NJ
Hi all , I just wanted to post a picture of what I found when working in a liquor store today. They are call mini spreaders. They are the perfect size for the small cups I use to mix epoxy and are made of stainless steel.
If you do any glass work with polyester resin then perhaps you are aware of the small, pink, plastic Bondo spatulas. Cut them to size and use them over and over. After the polyester, or epoxy, cures you just bend it and the hard, cured plastic pops right off. You can find them anywhere fiberglass and polyester resins are sold. For that matter, any type of polyethylene (LDPE, HDPE, UHDPE, etc) will suffice. It's just about like Teflon, hardly anything will stick to it.
I bought something like 20,000 little plastic cups from Sams Club for about $10. They are little plastic serviing cups. The kind that restaurants use for serving sour creme or salsa. About 2oz size.
I buy those little acid brushes by the gross from hobby lobby. Cheap.
Thse are more expensive, but it's what I buy from hobby lobby, for much less. They average out to about 6cents apiece.
http://www.microfasteners.com/catalo...NMTINBRUSH.cfm
I use popsicle sticks to mix. Just wipe the epoxy off with a paper towel while it's still wet. Use it a dozen times and then flip it over. Use the other side a dozen times.
These are expensive--but all they are good for is spreadin' epoxy:
[sm=lol.gif]
http://www.rcshowcase.com/html/acces...bulaprops.html
Use them and wipe the epoxy off while it's wet. If it dries--either sand it off with a palm sander or just cut the tip off.
[sm=lol.gif]
[sm=lol.gif]
[sm=lol.gif]
I use a small stainless steel spatula to mix and apply epoxy. The spaula is double-ended and about 8 inches long. When I'm done I wipe the spatula with a paper towl wet with methanol.
I think the spatulas are available from precision tool supply houses, maybe also places like www.digikey.com and www.mouser.com . They cost 5 or 10 dollars but last forever. I forget now where I got mine. I've never seen them in a LHS.
Edit.... Found it. This is what I talking about:
http://www.sargentwelch.com/product....+Double+Bladed
Edit again.... Can't get the link to work. go to www.sargentwelch.com and search on 'spatula'
My Feedback: (20)
GA
I use popsicle sticks.Box of 1000 from arts & craft store for $1.99 and
I save the plastic cups from jello snacks,fruit snacks and pudding snacks that my kids eat.
Always have plenty of cups.
SC
Hello!
Here's something a little different to use, I cut TIG (tungston inert gas) welding rods, 308L is the one I like (stainless), cut the wire to different sizes then I get out my hammer, lay 1 end on a piece of steel(vice, etc,), and hammer out the shape I want, file down the edges, use the epoxy dregs(leftovers) to make the "handel" it helps if you bend the handel end to a 90 degree first. when you use it, and don't have time to clean it off, just use a set of sidecutters to "snip" off the glue, no waste but the cured glue. Want a pic, hit me with a pm, glad to help, BTW, it cost me 5 bucks to make 9 sets (different shapes) of 4 to give the club mates at christmass.
old ranger
old ranger
