Remote ignition help. How do I do it?
PA
I have a Parkzone Stryker that I have modified to do over 100 mph but I would like to propel it even faster for a few seconds without sinking more money into motors and batteries etc...
What I want to do is attach a model rocket engine or two to the underside of the plane and ignite them either in sequence or just one for an extra burst of speed. I have free channels on my receiver but I am not sure what equipment I would need to ignite the rocket from a spare channel on my radio. Has anyone done this and have some links or pointers to help me finish this project? I already have mounts that I have made that align the rocket engine along the same thrust line but I am not sure how to ignite them via remote.
Any info is appreciated!
B
B
My Feedback: (47)
RE: Remote ignition help. How do I do it?
There are many concerns that I would have in doing this. First of all, all that exhaust heat will burn the crap out of your plane…and if you say that you’ll point the engine thrust at a slight downward angle, in order to clear the fuse, it will create positive lift. Now, how much more speed you will attain is debatable…at least that’s how I feel.
Are you using standard estes engines? What size? A, B, C, D, E? What about the parachute retro-charge (if your using estes engines)…How will you handle that discharge and exhaust?
You will have to get an extra servo to actuate a SPST switch, which will be attached to a 9 Volt battery and a standard estes rocket igniter. When you flip you retract switch, for example, the servo should move the switch from off to on and send 9 Volts to the igniter…And viola….instant fireball in the sky.
DISCLAIMER: Neither this website nor any of it’s affiliates, members, or cronies take any responsibility for ideas, however insane or shall be held liable for any errors, inaccuracies or content, or for any actions taken in reliance thereon. I EXPRESSLY DISCLAIM ANY LEVEL OF EXPERTISE IN THE AFOREMENTIONED TOPIC AND FURTHERMORE I QUESTION AS TO THE ACCURACY OF ANY CONTENT PROVIDED, OR AS TO THE FITNESS OF THE INFORMATION FOR ANY PURPOSE.
PA
Thanks for the info... I have D engines with no retro charge. I am making a mount that hangs off the bottom of the plane about 6 inches that is angled enough that it should not produce much if any thrust in the wrong direction.
I dont need the liability disclaimer. I am aware of what could happen, and will take the precautions nessisary. Its my decision and I dont plan on holding anyone else responsible.
NY
