Attaching Giant scale Windshield...?
Reply
Old 01-06-2007, 09:04 PM
dmcmike
My Feedback: (14)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default Attaching Giant scale Windshield...?
I'm just finishing up a Giant Aeromaster, (my first giant scale) and decided to put just a windshield on it (open cockpit), mainly because I lost the canopy that comes with the kit. Anyways, I've seen a lot of large planes with their windshields and canopys somehow screwed to the plane. I'm going into balsa, not ply, so I don't think that'll work. I'm using canopy glue on it right now, but I'm fully expecting it to come vibrating loose as soon as I start the G-62 in front of it. Any ideas, recommendations, etc.
mcmike
dmcmike is offline
Old 01-07-2007, 12:13 PM
Rcpilot
My Feedback: (78)
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Default RE: Attaching Giant scale Windshield...?
Back up your balsa with a couple little pieces of pine or bass wood. Screw into that. CA the holes and run the screws in and out a couple times. CA the holes again. That should keep the screws from stripping out.
Use trim tape. After the glue dries, you want to trim out the windshield with some 3/8" trim tape. Clean the covering very well first. Get all your fingerprints off and get all the oil and dirt off. Apply your trim tape.
That should hold it.
Rcpilot is offline
Old 01-10-2007, 09:13 PM
Hurri
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
I always get a piece of thin cardboard about say 2" wide x 5" long that will fit over the fuse where the windshield is going , use masking tape to hold it down , Now fit the windshield over as it it would fit . Use RC56 or similar to glue it on . Can use bathtub seal to finish around windshield when the RC 56 is dry . NOW---- take the cardboard off with the w/screen on , trim around the cardboard & glue that on to the fuse , easy & no mess with screws .
Hurri is offline
Old 01-10-2007, 11:17 PM
Campy
Campy's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
Do like you would for cowls.
Make your holes for the screws, then remove the screws and enlarge the holes until a piece of nyrod fits in the hole, then ca the nyrod in place and reinstally the screws. Screws will not come out.
Nyrod is the yellow inner part of "Gold-N-Rods". allyou need is a piece about 3/8" - 1/2" long for each screw.
Campy is offline
Old 01-12-2007, 04:52 AM
Stickbuilder
Stickbuilder's Avatar
Gallery
My Gallery
Models
My Models
Ratings
My Feedback
ORIGINAL: mcmike
mcmike
Are you looking for something quick and dirty, or do you wish to build a windscreen that is more scale appearing? If you don't mind a little work, I can walk you through one using brass and wood with acrylic windows. If you just want your existing windscreen to stay attached, c/a some small pieces of lite ply inside the fuselage, and sandwich the balsa with the screws. Good luck
Bill, AMA 4720
WACO Brotherhood #1
Stickbuilder is offline
Contact Us Archive Advertising Cookie Policy
